Pico W with Adafruit IO
kenidowa
Post by kenidowa »
I am using a Pico W with the latest Beta release of 8.0 release 4. I was working through a Adafruit learn exercise
"Quick-Start the Pico W WiFi with CircuitPython" https://learn.adafruit.com/pico-w-wifi- ... dafruit-io . The second to last one uses Adafruit IO. When I try to setup my device it does not have the Pico W as a device selection. Will this device get setup there?
mikeysklar
Re: Pico W with Adafruit IO
Post by mikeysklar »
You should not need to select your device based on the guide link you dropped.
Can you post a screen shot and the direct guide section link? This should be a matter of setting up the code.py / lib folder and .env file on the Pico W directly.
kenidowa
Post by kenidowa »
On the Adafruit IO site it asks you to select your device. https://io.adafruit.com/kenidowa/wippersnapper/new/
There are 17 devices non are the Pico W. All of them seemed to be ESP32's. So was thinking this one would need to be setup.
tannewt
Post by tannewt »
WipperSnapper is separate from CircuitPython. I don't believe it has Pico W support yet.
kenidowa
Post by kenidowa »
I understand that Whippersnapper is separate from Circuitpython but I started posting here because the Adafruit Learn https://learn.adafruit.com/pico-w-wifi- ... dafruit-io was for CircuitPython on a Pico W. I was using it to try out the lastest 8.0 Beta of CircuitPython and got to this second to last step/exercise and I couldn't complete it because the the Adafruit IO doesn't support Pico W. But it is part of this learn exercise and I thought someone might want to know. Just trying to be constructive and positive.
Ken
tannewt
Post by tannewt »
What step exactly? "On Adafruit IO, you can add the feeds to your dashboard to view your data over time." ? That could be better explained.
I think you clicked "New Device". Instead, try clicking "Feeds" and you should see "pitemp" and "pihumid" listed.
