Hi guys
Maybe somebody already tried this.
Can i run 4x 12V PC Fans (4pin PWM) over the Feather DC Motor Shield (max 6V)
but with extern 12V Power Supply?
Any advice or maybe a sheme of a working solution?
Thanks a lot
Feather shield 12V PWM possible?
Re: Feather shield 12V PWM possible?
PC fans typically expect a PWM frequency of 25KHz. The maximum frequency of the motor shield is 1.6KHz.
We do have a fan controller breakout here: https://www.adafruit.com/product/4808
- christofeugster
Thanks for this little but important detail.adafruit_support_bill wrote: ↑Thu Nov 24, 2022 8:06 am PC fans typically expect a PWM frequency of 25KHz. The maximum frequency of the motor shield is 1.6KHz.
- Can i connect 4 PWM Fans simultaneously on one breakout board you mention?
(All Fans have to spin the same RPM.)
- Or, can i connect 4x 4808 Breakout board to one Feather with 4 different I2c adress?
Thanks again
Chris
You can probably connect the PWM output to multiple fans, but you can only have tach feedback (for 4-wire fans) from one fan.
The device has a fixed i2c address. To connect multiples to a single Feather, you would need to use an i2c multiplexer. https://www.adafruit.com/product/2717
