I2C with Adafruit Feather STM32F405
PMLight
Post by PMLight »
Hey all,
I am very new to CircuitPython and trying to make a very simple I2C communication work.
I already have working arduino code (on a leonardo board) to initialize and set the output of a DAC:
#include <Wire.h>
#define AD56x5 (0x20 >> 1)
void setup()
  Wire.begin();
void loop()
  // Init
  Wire.beginTransmission(AD56x5);
  Wire.write(0x38);
  Wire.write(0x00);
  Wire.write(0x01);
  Wire.endTransmission();
  delay(100);
  // Vout=Vref
  Wire.write(0x1F);
  Wire.write(0xFF);
  Wire.write(0xFF);
   delay(1000);
I would now like to do the same with CiruitPython on the Feather STM32F405. From different examples I arrived at this:
import board
import busio
import time
i2c = busio.I2C(board.SCL, board.SDA)
from adafruit_bus_device.i2c_device import I2CDevice
device = I2CDevice(i2c, 0x10)
while True:
    with device:
        device.write(bytes([0x38]))
        device.write(bytes([0x00]))
        device.write(bytes([0x01]))
        time.sleep(0.001)
    with device:
        device.write(bytes([0x1F]))
        device.write(bytes([0xFF]))
        time.sleep(1)
Obviously I'm missing something, because the CircuitPython code doesn't work (nothing is happening). The adress 0x10 is found, when doing an I2C scan. Can you point out my error?
blakebr
Re: I2C with Adafruit Feather STM32F405
Post by blakebr »
delay(100) is not the same as time.sleep(.001); time.sleep(0.1) is the same as delay(100).
Bruce
adafruit_support_carter
Yep, try fixing timing. Also, can write all the bytes with a single call:
    with device:
        device.write(bytes([0x38, 0x00, 0x01]))
    delay(0.1)
    with device:
        device.write(bytes([0x1F, 0xFF, 0xFF]))
    delay(0.1)
