Hi, first time poster here. Please point me in the right direction if you can.
I'm trying to get the Solenoid Drums project going. Everything is connected as it should be. I have a code error which I do not understand:
In file included from c:\Users\jagbr\BANNED\Documents\Arduino\libraries\Adafruit_Seesaw-master/Adafruit_Crickit.h:4,
from C:\Users\jagbr\AppData\Local\Temp\.arduinoIDE-unsaved20221024-9056-fdulbs.wjm7\sketch_nov24a\sketch_nov24a.ino:2:
c:\Users\jagbr\BANNED\Documents\Arduino\libraries\Adafruit_Seesaw-master/Adafruit_seesaw.h:24:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
24 | #include "Adafruit_I2CDevice.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
I copied the code from the page but I think it's something to do with my directory structure.
Any help would be cool as fudge!
Will.
Help with code
- Franklin97355
Re: Help with code
There was a post in 2020 about this, I don't know if it is relevant but you can look into it.
adafruit_support_carter wrote:Here's the repo where it lives:
https://github.com/adafruit/Adafruit_BusIO
The EPD library depends on the GFX library:
https://github.com/adafruit/Adafruit_EP ... erties#L10
which depends on the Bus IO library:
https://github.com/adafruit/Adafruit-GF ... erties#L10
So that dependency linkage should have installed all the necessary libraries. But that feature does not exist for Arduino version prior to 1.8.10, so you have to do it manually.
