MPR121 Arduino sheild and USB midi.
- wiremonkey
I am trying to use the MPR121 arduino shield with a leonardo to send midi via usb. I can get it to read via the serial monitor fine. I am using a USB Midi library and the test file works no problem. When I put them together I get no midi. Is it possible to send midi via usb while using the MPR121 shield or is there incompatibility with both?
- blnkjns
Re: MPR121 Arduino sheild and USB midi.
Should not be a problem, the shield uses I2C. Maybe you can post the code that throws errors.
