Hi, I'm working with a new #4913 Mini Skinny Neopixel strip / 60 @ 1m. On first hookup it dropped my 5V 2A wall wart supply to 1V. Subsequent connection to my bench supply has it drawing 4A at 2.43V, all LEDs dark. If fact, I've never seen any of the Neopixels illuminate. Polarity of the 5V supply has been checked multiple times. The bench test had the QT Py (data and ground) disconnected. I'm using Anderson power pole connectors to the bench supply and Wago LeverNuts to make ground and data connections to ferruled leads to a QT Py SAMD21. I use the green and black 5.5/2.1mm screw terminal to barrel/coax connectors which I know are best below 3A. The photo shows the JST Female SM pigtail leads I'm using. There's no short between any combination of the three leads.
My sole concern is the current draw and whether this is a warranty issue. I'll worry about the data line & level later. The strip has not been removed from the reel, nor has it been powered for more than a few seconds at a time. This is my first "call" to support in many years of being a happy customer. Thanks!
Order #2963257-9020169957, 2022-11-19.
Excessive current on new Neopixel strip
- lothar77
- PXL_20221126_214324711.jpg (363.49 KiB) Viewed 124 times
- dastels
Re: Excessive current on new Neopixel strip
Can you measure the resistance between the strip's power and ground connections (without power attached) in both directions, please? Can you visually inspect the ends of the strip where the wiring is attached? Maybe post clear closeup images?
- lothar77
Hi Dave. Sorry for the delay - I was traveling.
Here are my measurements using a Beckman Industrial meter (old but good!):
Identical reading on both ends - the male, pinned connector and the female, socket connector.
1.11kΩ resistance test, red to black
1.11kΩ resistance test, black to red
0.979V diode test Vf, red to black (Vf for 1mA current as I recall)
0.428V diode test Vf, black to red
The soldering at the male connector looks good. I'll post a photo. The solder joints for the female connection are covered by the end cover are are barely visible.
- lothar77
Photos as requested. As noted above, the solder joints on 1 end are visible, the solder joints on the other end are not.
- 2022_1203_193421_003.JPG (379.67 KiB) Viewed 58 times
- 2022_1204_134729_005.JPG (447.07 KiB) Viewed 58 times
- dastels
Even so, they all look as I'd expect.
I'm thinking that there's a short somewhere on the strip. Please email [email protected] with a link to this thread, your order number, and request the replacement of one Mini Skinny NeoPixel LED Strip - Warm White 3000K - 60 LEDs/m - 1m long.
