I am trying to control servos with a PCA9685 and Raspberry pi Pico board using the editor Mu and Circuit Python. I am new to Circuit python and believe someone with more experience could easily help.
The wiring of the board looks correct. I have downloaded Circuit python and Installed the necessary libraries the tutorial instructs (https://learn.adafruit.com/16-channel-p ... cuitpython) however, when I enter the code that the tutorial uses as a demo to control a standard servo, nothing happens. I don't know if I entered the code incorrectly or if the libraries are imported correctly but some help would be appreciated. I have read as much documentation as I could find but there isn't much and most is outdated
Thanks, Tannar
SG90 servo control with PCA9685 and Raspberry Pi Pico board
- Tannar
- Circuit Library.PNG (10.54 KiB) Viewed 72 times
- CircuitCode.PNG (31.75 KiB) Viewed 72 times
- Franklin97355
Re: SG90 servo control with PCA9685 and Raspberry Pi Pico board
By 'nothing happens' do you mean the servo does not twitch when plugged in or just does not move? try moving it to 180, wait a bit, and then move it to 0 and see what happens. Also post a picture of your connections to both the servo and the controller.
- Tannar
Thank you for responding. When I said nothing happened, the servo doesn't move or twitch when the code is run. I tried setting it to 180, 90, and 0 and still nothing. Here is the wiring:
- Pico#1.jpg (114.11 KiB) Viewed 51 times
- Pico#2.jpg (1021.63 KiB) Viewed 51 times
- Pico#3.jpg (992.3 KiB) Viewed 51 times
