Recommended Connector
flavinny
Post by flavinny »
I intend to build a three-phase rectifier using a Protoboard diodes etc. purchased here. I need connectors on the board that would allow me to connect and disconnect the three input wires and the two output wires. Slip on type connectors would be preferred but screw clamp type would work.
Part numbers would be appreciated.
adafruit_support_mike
Re: Recommended Connector
What voltage and current levels will you be using?
"Three-phase" usually means 240V-per-phase and industrial currents in the tens of amps. A prototyping board can't survive that much power.
