Hi :)
I want to use sscanf to parse a formated serial input into different variables.
Something like "sscanf(SerString, "%s %d %f", SerCmd, &SerInt, &SerFloat);". But SerFloat is always 0.0.
Does anyone have an idea what may be the reason or how to work around it?
Tanks a lot! :)
sscanf doesn't work (Arduino IDE)
Re: sscanf doesn't work (Arduino IDE)
What processor are you using? %f is not supported on some microcontrollers due to space limitations.
https://arduino.stackexchange.com/quest ... ing-sscanf
- Mandel
I use a ItsyBitsy M0 Express. So it should be a SAMD 21
- Mandel
I found a solution for the problem.
Putting asm(".global _printf_float"); and asm(".global _scanf_float"); in the setup and including #include <avr/dtostrf.h>
The M0 probably has enough flash memory to handle the added library overhead. And enough RAM for the necessary buffering. Though you should keep an eye on run-time memory utilization as these functions can lead to fragmentation.
You would need to enable floating point parsing explicitly in the compiler/linker command line as described here: https://forum.arduino.cc/t/floating-poi ... nfo/361737
For questions regarding modifications to the IDE, the Arduino forum is your best resource.
The other approach is to use atof() for parsing floating point. That is more efficient and better behaved than sscanf.
