RA8875 and NHD-7.0
JC_Buron
RA8875 and NHD-7.0
Post by JC_Buron »
I use a RA8875 for drive a NHD-7.0-800480EF-ASXN.
I thought this one would work fine considering the similar specs to your TFTs. When I try with the examples of the library associated with RA8875, the first example "buildtest" gives me only a slight flash on the screen then nothing. What could be the problem with this malfunction? Thank you for your help.
Best regards.
Jean-Claude Buron
JC_Buron
Re: RA8875 and NHD-7.0
Post by JC_Buron »
Could tech support help me set up the PLL and clocks so that the RA8875 module can work with the NHD-7.0-800480ASXN display.
I can not attach the specifications of the display, so I put the link :
https://newhavendisplay.com/content/spe ... F-ASXN.pdf
I count on you, thank you in advance.
Best regards.
Jean-Claude Buron
