Expanded Laser Engraving Area
tcordova
Post by tcordova »
I have a small Ortur Laser engraver. I want to expand the engraving from 6" square to 12" square(?) engraving area.
I purchased what I thought was the correct 4 pin connector and socket, JST PH 2.0mm set. Turns out this is not the connector/ socket type. Can anyone tell me what I have?
Thank you
attachments (1).zip
(426.77 KiB) Downloaded 11 times
mikeysklar
Re: Expanded Laser Engraving Area
Post by mikeysklar »
You could hold the JST-PH part you purchased up against the laser connector for reference.
If you have calipers measure the part outside diameter and pin spacing on center for the headers.
Adafruit sells a variety of JST SH pins connectors (which are smaller than PH), but I'm not sure that SH is what you need.
https://www.adafruit.com/?q=jst+sh+4-pin&sort=BestMatch
Take a look at all the options here to help determine what you have:
https://en.wikipedia.org/wiki/JST_connector
Screenshot from 2022-11-30 11-43-27.png (158.26 KiB) Viewed 78 times
tcordova
Post by tcordova »
Thank you,
I will take your advice and post results for other.
