The problem is as values update the previous values are not cleared, or overwritten, so they are one on top of the other. After a few minutes some of the characters are just a blur.
Am I not formatting the value correctly, can I set the background of the character to black, is there a different way to send both the text and value in the same line?
Thanks for your help the code is below
John
Read Temp and Humidity
Dislay on OLED
import board
import displayio
import terminalio
import adafruit_shtc3
import time
# can try import bitmap_label below for alternative
from adafruit_display_text import label
import adafruit_displayio_sh1107
displayio.release_displays()
# oled_reset = board.D9
# Use for I2C
i2c = board.I2C()
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
# i2c = board.STEMMA_I2C() # For using the built-in STEMMA QT connector on a microcontroller
sht = adafruit_shtc3.SHTC3(i2c)
# SH1107 is vertically oriented 64x128
WIDTH = 128
HEIGHT = 64
BORDER = 2
display = adafruit_displayio_sh1107.SH1107(
display_bus, width=WIDTH, height=HEIGHT, rotation=0
# Make the display context
splash = displayio.Group()
display.show(splash)
color_bitmap = displayio.Bitmap(WIDTH, HEIGHT, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0xFFFFFF # White
#bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
#splash.append(bg_sprite)
# Draw a smaller inner rectangle in black
#inner_bitmap = displayio.Bitmap(WIDTH - BORDER * 2, HEIGHT - BORDER * 2, 1)
#inner_palette = displayio.Palette(1)
#inner_palette[0] = 0x000000 # Black
#inner_sprite = displayio.TileGrid(
# inner_bitmap, pixel_shader=inner_palette, x=BORDER, y=BORDER
#splash.append(inner_sprite)
# Draw some white squares
#sm_bitmap = displayio.Bitmap(8, 8, 1)
#sm_square = displayio.TileGrid(sm_bitmap, pixel_shader=color_palette, x=58, y=17)
#splash.append(sm_square)
#med_bitmap = displayio.Bitmap(16, 16, 1)
#med_square = displayio.TileGrid(med_bitmap, pixel_shader=color_palette, x=71, y=15)
#splash.append(med_square)
#lrg_bitmap = displayio.Bitmap(32, 32, 1)
#lrg_square = displayio.TileGrid(lrg_bitmap, pixel_shader=color_palette, x=91, y=28)
#splash.append(lrg_square)
# Draw some label text
#text1 = "0123456789ABCDEF123456789AB" # overly long to see where it clips
#text_area = label.Label(terminalio.FONT, text=text1, color=0xFFFFFF, x=8, y=8)
#splash.append(text_area)
#text2 = "SH1107"
#text_area2 = label.Label(
# terminalio.FONT, text=text2, scale=2, color=0xFFFFFF, x=9, y=44
#splash.append(text_area2)
while True:
temperature, relative_humidity = sht.measurements
print("Temperature: %0.1f C" % temperature)
print("Humidity: %0.1f %%" % relative_humidity)
print("")
text1 = "Temperature: %0.1f C" % temperature
text2 = "Humidity: %0.1f %%" % relative_humidity
terminalio.FONT, text=text2, scale=1, color=0xFFFFFF, x=9, y=44
time.sleep(1)
