ItsyBitsy NRF52840 power consumption
- amowry
I'm seeing that this board consumes about 7 mA running a "bare minimum" Arduino sketch. I was expecting it to be less based on what I've read on the Nordic site. I understand that the DotStar has some quiescent current in the <1 mA range, but other than desoldering that, are there suggestions for reducing the consumption of this board?
- mikeysklar
Re: ItsyBitsy NRF52840 power consumption
You can bypass the voltage regulator. Try pulling EN low and supplying 3v3 through the BAT pin.
- amowry
Am I correct that delay() should put it into low power mode? I'm not seeing any change in consumption with an extended delay.
- mikeysklar
I do see a thread that mentions delay(100) 600uA. Had you come across this?
https://github.com/adafruit/Adafruit_nR ... issues/165
- amowry
Thanks-- I had seen that, but it's not clear to me whether that functionality is implemented for this board (?). I thought I had read somewhere that delay() puts all the NRF52840 boards into sleep mode. Is there someone who could clarify that for me?
mikeysklar wrote: ↑Thu Dec 01, 2022 5:57 pm I do see a thread that mentions delay(100) 600uA. Had you come across this?
- mikeysklar
There are some good threads in the Adafruit nRF52 repo related to super low power consumption for the nRF52840.
https://github.com/adafruit/Adafruit_nR ... /issues/51
The delay == sleep is true and mentioned here:
https://learn.adafruit.com/bluefruit-nr ... aq-3026483Throughput
Power Consumption
- delay = sleep thanks to freeRTOS tickless https://www.freertos.org/low-power-tickless-rtos.html
- amowry
Thanks, I've made some progress after reading those threads.
Has anyone here successfully enabled the internal DC/DC converter? The RayTac module has the necessary circuitry for it, and if I'm reading the Nordic documentation correctly, it reduces the CPU consumption by a whopping 3mA!
Or is the DC/DC enabled by default by Adafruit? I haven't found a reference for it?
From the Nordic documentation:
- DC-DC-consumption.jpg (44 KiB) Viewed 154 times
