I am having issues compiling the code from this project: https://learn.adafruit.com/neopixel-painter/download
I am trying to compile the code for an arduino Nano, which should work with this project. Right off the bat I get this error: "Compilation error: ./gamma.h: No such file or directory". Included with this project is the gamma.h library, which I have made an appropriate folder for and copied it into in the libraries folder. I can fix this issue by simply removing the "./" from in front of gamma.h.
Next I get: "Compilation error: 'SdCard {aka class DedicatedSpiCard}' has no member named 'readBlock'; did you mean 'readStop'?"
Can anyone try running this code on an Nano or Uno, or help me get this running? Thank you!
Neopixel Painter Help!
Re: Neopixel Painter Help!
The gamma.h file should live in the same directory as the sketch file. It isn't a library per se, just a resource file.
