I ordered the Slim Fingerprint Sensor (4750) and I recently hooked it up with a USB to UART converter to my Rasberry Pi and when I touched the sensor pad it was extremely hot. I unplugged it and tried only directly hooking up power and ground to the Rasberry pi and it still got hot. I think this might be due to a short circuit in the sensor although I'm not sure what could have caused this. What should I do?
Slim Fingerprint Sensor 4750 Short Circuit
- mikeysklar
Re: Slim Fingerprint Sensor 4750 Short Circuit
Without connecting it to the Pi can you show the wiring you used between the fingerprint sensor and the USB to UART converter?
Which guide were you following for the pins to use?
- swagginty
Hi, thanks for your response. Yes, Here is my wiring.
- mikeysklar
Those connections look tenuous. Are you only using electrical tape or are they soldered?
Try using these for the pinouts. Don't only go by color, but also by pin number from left to right. Notice how the red is GND and black is RX (not intuitive).
Can you take a picture of the back of your slim connector while it is plugged in so we can verify the wire colors? The product page suggestions these pinouts. I noticed your yellow wire was not connected.
https://www.adafruit.com/product/4750
Black to GND
Yellow to Microcontroller TX (data out from microcontroller)
Green to Microcontroller RX (data in from microcontroller)
Red to 3.3V VIN
White to IRQ (can leave disconnected)
Blue to 3.3V VCC (can leave disconnected)
- swagginty
The connections are soldered under the electrical tape. I switched to the right pinout (according to color) but I think you're right about the pinout number thing. I'm looking at the picture from the website and it looks like the colors are mirrored. Here is a picture of mine.
And a picture from the website. Do you think this is the issue?- mikeysklar
Using the color chart I provided should be the correct layout. On another site it shows the pin ordering from left to right (ignore the colors there).
https://wiki.dfrobot.com/Capacitive_Fin ... KU_SEN0348
Walk me through your current connections to the FTDI now that you have changed it.
- swagginty
Right now I have 1 going nowhere, 2 to nowhere, 3 to power, 4 to UART white, 5 to UART green, and 6 to GND
- mikeysklar
I think you are reading it in reverse.
pin# | color | connection
1 | black | GND
2 | yellow | Microcontroller TX (fingerprint RX)
3 | green | Microcontroller RX (finger TX)
4 | red | 3v3 Vin
5 | white | disconnected
6 | blue | disconnected
1 | black | GND
4 | red | 3v3 Vin
- swagginty
Ya, that's how I have it wired right now. At least I have those colors going to those places. But in the diagram it looks like 1 corresponds to where my blue wire is, 2 to white, and so on.
- mikeysklar
Please post a photo of your current wiring. The earlier photo did not show yellow connected to anything and white was being used (should be disconnected).
- swagginty
This is my current wiring.
- wires_3.png (945.75 KiB) Viewed 72 times
- mikeysklar
Thank you for the photo. That is good quality and I can see everything.
The current wiring you have matches the Adafruit product page and guide instructions. You have the correct wires connected.
Have you plugged it back into your Pi? Does it still get hot? Do you see anything via serial console or dmesg?
