Greetings.
I'm Jesse, I'm a student at the university and I'm making a True or False quiz game as a project, using MakeCode and two CPXs. There's a point in the programs where I need both CPXs to run a function synchronized, so I'm trying to set commands to make one wait for the other. I've tried a couple of methods, but I can't get it to work properly. Could anyone tell me what I could try, how I could make it possible or at least what funcitons / commands I could try using? If possible, via infrared signals.
Thank you so much in advance.
Can I make a CPX wait for another one before continuing?
- Jesse_01
- mikeysklar
Re: Can I make a CPX wait for another one before continuing?
Have you established communication between the two CPX modules? If so, what are you using?
We don't have a guide specific to what you are asking, but you could use the TTL UART RX/TX pins between two CPX's to send data between them. That would allow you to send numbers/characters between the two devices.
https://learn.adafruit.com/circuit-play ... onnections
- johnpark
Would something like this do what you need? It just calls the same function on send as is does on receive.
