Good morning.
I purchased several FeatherWing LIS3MDL boards, specifically - https://www.adafruit.com/product/4565
I was going to stack them with several other FeatherWing components (an esp32-S2 and lcd display)
The SDA/SCL pins on the LIS3MDL board are reverse of what they are on the other two boards. See attached image.
Is this just a labelling glitch?
Thank you,
Bob
Adafruit LSM6DSOX + LIS3MDL FeatherWing SCL & SDA Pins seem backward, as labelled
- bobbertolino
- lis3mdl.png (280.52 KiB) Viewed 39 times
- dastels
Re: Adafruit LSM6DSOX + LIS3MDL FeatherWing SCL & SDA Pins seem backward, as labelled
As noted on the pinout page in the guide https://learn.adafruit.com/st-9-dof-com ... dl-pinouts:
DaveOn the earlier versions of the FeatherWing, SCL and SDA are swapped on the silk. The pins themselves are accurate. The issue is only with the labels printed on the board.
