I am new to programming microcomputers. I want to run animated giffs in led light boxes i have made. I am an artist and just started to learn how to create these gifs in photoshop. What micro controller would be best to use? Also, if using a ardruino, what program should i use to convert giff . so that the microcomputer can read and send it to the leds? I would like to achieve these goals with the simplest means . Attached is an example of a box where I set up colors by using separate controlled led bands manually. for this project i want to run a animated gifs that fade into other colors over time
How to run animated gifs in led light box
- grettagirl
- Screen Shot 2022-12-02 at 12.08.28 PM.png (648.24 KiB) Viewed 84 times
Re: How to run animated gifs in led light box
Have a look at this guide: https://learn.adafruit.com/animated-gif ... rix-portal
[Edit] Looks like you already have a thread on this topic. Please continue it there:
viewtopic.php?t=196507
