Magic Band Reader Tutorial - Constantly playing until RFID scanned
outletpro
Post by outletpro »
I was wondering if anyone can help or has also had this issue with the Magic Band Reader Tutorial using the Adafruit Feather RP2040. I ran into an issue where when I plug in the USB on the Feather RP2040, the lights will spin and the audio clips will continue to play. I noticed that if I scan my RFID tag it will pause the lights and the sound but then continue again.
All of my wiring matches the tutorial and I looked through the python code but the only mistake I could see was that the pixel number was set to 24 instead of 31. I corrected that part to use all of the LEDs in my project but I do not see anything that I could change in the code to correct the issue I am having. Is there an issue in the Libraries?
Has anyone else had this issue and if so, were you able to correct it? Thanks!
dastels
Re: Magic Band Reader Tutorial - Constantly playing until RFID scanned
Post by dastels »
Check my response to the other post about this (that you also commented on).
