Heatsink for 70mm led ring bulb prodduct#5138
- Bradenandrey
Hi, I was seeing if anyone can help me find the right size Heatsink to cool the bulb down. I’m totally new to this stuff. When the light is on after a couple minutes it looks like a bit a smoke is happening. Any help would be greatly appreciated.
- mikeysklar
Re: Heatsink for 70mm led ring bulb prodduct#5138
You could purchase some thermal tape and use a chunk of metal (steel, aluminum, whatever you have).
https://www.adafruit.com/product/1468
Adafruit does sell some heat sinks, but most of them are chip sized.
https://www.adafruit.com/?q=heat+sink+f ... =BestMatch
You can also use PWM or lower voltage with a diode to run the light cooler.
Depending on the application, these would typically be attached to an aluminum plate or ring with a thermal adhesive. You can find aluminum disks and rings of various sizes on Etsy.
We do have one that comes pre-attached to a ring here: https://www.adafruit.com/product/4433
