I'm trying to get the feather esp32-s2 to work with two different VL53L1X sensors.
How would I change the sketch below to add the second sensor?
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "Adafruit_VL53L1X.h"
Adafruit_VL53L1X vl53 = Adafruit_VL53L1X();
Adafruit_SSD1306 display = Adafruit_SSD1306();
#if (SSD1306_LCDHEIGHT != 32)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
Serial.begin(115200);
while (!Serial) delay(10);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)
// init done
display.display();
delay(1000);
Serial.println(F("Adafruit VL53L1X sensor demo"));
pinMode(PIN_I2C_POWER, INPUT);
delay(1);
bool polarity = digitalRead(PIN_I2C_POWER);
pinMode(PIN_I2C_POWER, OUTPUT);
digitalWrite(PIN_I2C_POWER, !polarity);
Wire.begin();
if (! vl53.begin(0x29, &Wire)) {
Serial.print(F("Error on init of VL sensor: "));
Serial.println(vl53.vl_status);
while (1) delay(10);
Serial.println(F("VL53L1X sensor OK!"));
Serial.print(F("Sensor ID: 0x"));
Serial.println(vl53.sensorID(), HEX);
if (! vl53.startRanging()) {
Serial.print(F("Couldn't start ranging: "));
Serial.println(F("Ranging started"));
// Valid timing budgets: 15, 20, 33, 50, 100, 200 and 500ms!
vl53.setTimingBudget(50);
Serial.print(F("Timing budget (ms): "));
Serial.println(vl53.getTimingBudget());
vl.VL53L1X_SetDistanceThreshold(100, 300, 3, 1);
vl.VL53L1X_SetInterruptPolarity(0);
int16_t distance;
if (vl53.dataReady()) {
// new measurement for the taking!
distance = vl53.distance();
if (distance == -1) {
// something went wrong!
Serial.print(F("Couldn't get distance: "));
return;
Serial.print(F("Distance: "));
Serial.print(distance);
display.clearDisplay();
display.setCursor(0,0);
display.setTextSize(2);
display.setTextColor(WHITE);
display.print(distance);
display.print("mm");
display.display();
Serial.println(" mm");
// data is read out, time for another reading!
vl53.clearInterrupt();
