Ethernet FeatherWing MAC / IP troubles circuitpython
HorstO
Post by HorstO »
Hi, I am using a ESP32-S2 TFT Feather (https://www.adafruit.com/product/5300) with the ethernet feather wing (https://www.adafruit.com/product/3201) via a FeatherWing doubler (https://www.adafruit.com/product/2890).
I have added a screenshot of what I am getting with the example ethernet featherwing circuitpython code (same as provided here: https://learn.adafruit.com/ethernet-for ... thon/usage).
First of all, I am getting a strange MAC address printed out (the string reads "deadbeeffeed" which sounds like a debug string) - it certainly does not match the one that was delivered with the ethernet featherwing (print on sticker). I need the correct MAC address to hook it up to the ethernet in my institute.
Then, adafruit.com is successfully looked up, but even for the "text" URL
TEXT_URL = "http://wifitest.adafruit.com/testwifi/index.html"
I am getting an immediate error: SSL not supported by circuitpython library.
I don't think the problems are related, but I would be grateful for some advice on either!
screenshot repl
screenshot repl
mikeysklar
Re: Ethernet FeatherWing MAC / IP troubles circuitpython
Post by mikeysklar »
The default mac address is set in the CircuitPython library. It is DEADBEEF just as you see in the example code.
# Default hardware MAC address
DEFAULT_MAC = (0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED)
https://github.com/adafruit/Adafruit_Ci ... iznet5k.py
SSL is not supported with CircuitPython:
        :param tuple address: Remote socket as a (host, port) tuple.
        assert (
            conntype != 0x03
        ), "Error: SSL/TLS is not currently supported by CircuitPython."
https://github.com/adafruit/Adafruit_Ci ... arch?q=ssl
HorstO
Post by HorstO »
Thanks, @mikeysklar, all clear!
blakebr
Post by blakebr »
Mike,
If I read you right CP assigns the same MAC address to all interfaces. Won't there be an issue with multiple CP managed ethernet devices having the same MAC address of de:ad:be:ef:fe:ed? I had that problem when I purchased several low cost micro-USB to Ethernet converters for my RPi Zero W devices. I spent many hours trying to figure out what the problem was. When I found that they all had the same MAC address they went in the trash and I got better ones. No problems since.
Bruce
mikeysklar
Bruce,
You assign the mac address in the CircuitPython script (with the constructor mac=)so it is very much in the hands of the user. I like that it is easy to change and does not require any obscure tools. It can make it easy to identify and differentiate your boards.
class adafruit_wiznet5k.adafruit_wiznet5k.WIZNET5K(spi_bus, cs, reset=None, is_dhcp=True, mac=(222, 173, 190, 239, 254, 237), hostname=None, dhcp_timeout=30, debug=False)
https://docs.circuitpython.org/projects ... k.WIZNET5K
blakebr
Post by blakebr »
Mike,
I am glad to see there is a way. I would like to do it on an RPi Pico W with CP 8.0.0 Beta 5. As I don't setup the SPI buss, how would I do it for this MC? TIA
Bruce
mikeysklar
For an RP2040 you would set the mac using something like this:
spi_bus = busio.SPI(board.GP6,board.GP7,board.GP4), board.GP9)
eth = WIZNET5K(spi_bus, mac=(222, 173, 190, 239, 254, 237))
