Lightweight Engine Sound Generator
- svenyonson
I'm looking for a minimalist solution for a Trinket M0 to loop a small wave file, and be able to adjust the output sample rate to simulate throttle. I need to drive a small speaker (26.5mm). Do I need a separate amplifier chip or will the M0 be able to drive the speaker directly? This is going into a small r/c plane, every gram saved is a good thing. I only need one engine sample, wondering if I can use the onboard 256KB flash for this? Anyone done something similar that can share project details?
- mikeysklar
Re: Lightweight Engine Sound Generator
With CircuitPython you can play WAV files right off the SAMD21 Trinket M0 hardware.
https://learn.adafruit.com/make-it-talk/circuitpython
Would the STEMMA speaker meet your needs?
https://www.adafruit.com/product/3885
- svenyonson
Thanks! Both excellent suggestions. I am going to order the speaker and play around with it.
