Adafruit Library Error
_phillip
Post by _phillip »
Yesterday my sketch worked perfectly and today this compiler error popped up:
 file included from /Users/myName/Documents/Arduino/Talavera ƒ/talavera_north_tank_3DEC2022-v00/talavera_north_tank_3DEC2022-v00.ino:595:
/Users/myName/Documents/Arduino/libraries/Adafruit_LiquidCrystal/Adafruit_LiquidCrystal.h:9:10: fatal error: Adafruit_MCP23X08.h: No such file or directory
    9 | #include <Adafruit_MCP23X08.h>
I do recall the Arduino IDE suggesting I 'update' some libraries yesterday and am wondering if this triggered this compiler error.
I came across this and wonder if it is a patch for this error.
https://github.com/adafruit/Adafruit-MC ... MCP23X08.h
Any help with this will be greatly appreciated.
Thank you.
adafruit_support_carter
Re: Adafruit Library Error
The Adafruit_LiquidCrystal went through a recent update which removed the built in MCP23008 support and replaced it with the existing MCP library:
https://github.com/adafruit/Adafruit-MC ... no-Library
As of the 2.0.0 release of Adafruit_LiquidCrystal, that is now a dependency.
Any new install should automatically install the dependency. For existing installs (your case), you may need to manually install the Adafruit-MCP23017-Arduino-Library. It should be available via the Arduino Library Manager.
_phillip
Post by _phillip »
THANK YOU, SIR!!!!
That did it. I also had another issue with the NTPClient.h lib not including the 'getFormattedDate()', but I am aware of that and know how to get around it.
I am getting very leery of 'updates'. LOL!
I sincerely appreciate your help.
MICHAEL_COLUZZI
Post by MICHAEL_COLUZZI »
Tried to compile with that adafruit library and received the error
libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp:352:61: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
Using arduino IDE and the latest adafruit libraries v1.0.0
@MICHAEL_COLUZZI Please start a new thread for your issue.
MICHAEL_COLUZZI
Updated Arduino to latest IDE and adafruit library 1.0.0 for MSA311 and get errors:
Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp:352:61: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
_spi->transferBytes(prefix_buffer, nullptr, prefix_len);
Arduino15/packages/firebeetle32/hardware/esp32/0.1.1/libraries/SPI/src/SPI.h:73:10: note: initializing argument 1 of 'void SPIClass::transferBytes(uint8_t*, uint8_t*, uint32_t)'
void transferBytes(uint8_t * data, uint8_t * out, uint32_t size);
Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp:355:47: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
_spi->transferBytes(buffer, nullptr, len);
Adafruit_BusIO/Adafruit_SPIDevice.cpp:446:59: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8_t* {aka unsigned char*}' [-fpermissive]
_spi->transferBytes(write_buffer, nullptr, write_len);
@MICHAEL_COLUZZI Please start a new thread for your issue. Locking this thread.
Return to “Arduino”
