Hi All,
Brand new to CircuitPython. I just got a Circuit Playground Express for a prototype sensor project I want to experiment with.
Background, I'm an experienced developer but very rusty, as I have been doing more business and management stuff for the past couple of decades. I was an ET in the service, and I have a BSCS. I have done some Arduino and RPi projects, just not any production coding for a long time. I have professionally programmed in C, Autolisp, C++, VB, Java, and SQL. I was of the church of Emacs for a long time but again, so rusty... I DON'T have a favorite editor right now, hence this post.
I have a little Python experience and want to become an expert. I'm trying to decide what environment to use going forward. I have searched this forum and the web and didn't really find a good answer. I thought this might be a good thread to have here at the mothership for both beginners and newbies to CircuitPython!
I'm on Windows 10-64bit. I see my main choices as below with pros and cons. Please comment and advise!
Mu
https://learn.adafruit.com/welcome-to-c ... -mu-editor
Recommended as Atom.io is going away this month. Focus on the code, not the environment. Not a "professional" environment for commercial/production programming.
Jupyter
https://learn.adafruit.com/circuitpytho ... -notebooks
I'm using it for Big Data and other Python AI classes I have going. Also, I may want to collect a lot of data for off-line so Pandas and whatnot might be handy. Good environment to self-document my project and potentially share. Anaconda is well supported and should be around for a while.
VS Code
https://marketplace.visualstudio.com/it ... cuitpython
"Professional" development environment, also well supported. Support for GIT, and just about any other tool I might need including big data. Not as portable to Mac, Windows does have WSL for Linux support.
TIA,
Paul
Development Environment
- dastels
Re: Development Environment
With CircuitPython you can use anything you want. Some have better support for Python than others.
Personally I use Emacs with elpy, working with local files with a custom command line script (written in python currently) to deploy/update code/libs/files to /CIRCUITPY.
Given your experience, I suspect you may find Mu overly simple and limited. It's a great beginner environment, though. VS-Code is well reputed.
I think the key is to find something that you are comfortable using.
- pgrunwald
Thank you for the reply Dave. Is your script publicly available? I'm intrigued and for whatever reason, I had not considered EMACS for python development but I will! https://realpython.com/emacs-the-best-python-editor/
Best,
Paul
- dastels
- chadlung
I've been using PyCharm and Adafruit has a guide to get things set up correctly:
https://learn.adafruit.com/welcome-to-c ... cuitpython
Good luck.
Good luck.
- westfw
I don’t know that I’d want to use a circuit/micro-python-specific ide. VSCode seems to be popular partially because it supports multiple languages, presumably similar to EMACS modes…
PC-side I’ve used “spyder” (it came with “Anaconda”, that some MOOC recommended.)
It has pretty impressive debugging support, but I don’t know whether it has any support for talking to micros.
And EMACS’s Python mode is just fine…
