I'm following/enhancing the project here https://learn.adafruit.com/circuitplayg ... /change-it. Using my express, my goal is to build a morse code flasher so the subtle changes in the LED flashes are very important to distinguish between Morse's dashes and dots. I was experimenting with adding tone noises in simultaneously with the lights. Any time I try to add tones via cpx.play_tone(270, 1) it causes the LED flashes to become far slower/more drawn out, therefore slowing down the speed of the morse code.
Is it expected that the circuit processing the tone function would slow down the LED flashes? I'm a newbie to coding and circuitry so it might just be a software (or user!) issue.
Simultaneous tone and light flash
- Arnie_Pi_in_the_sky
- mikeysklar
Re: Simultaneous tone and light flash
Yes, adding a tone could slow down the flashes.
Do you want to post your code? We might be able to suggest a way to speed it up so you can do both.
Thank you for the quick response, mikeysklar!
My first attempt was to add cpx.play_tone(262, 1) into the light function (which is inside the MorseFlasher class). This slows down the LED flashes and the dots vs. dashes are indistinguishable. If I remove this line, the code/LED flashes work perfectly fast!
How the code works: the user presses button A and a number from 1-3 is chosen at random and communicated via Morse code through LED flashes. If button B is pressed after button A, it will re-display the same message. If the user presses button A again, another message randomly chosen from the list will be displayed.
import time
import board
import random
from adafruit_circuitplayground.express import cpx
# Message to display
messageList = ['3', '2', '1']
# Configuration:
dot_length = 0.2 # Duration of one Morse dot
dash_length = (dot_length * 3.0) # Duration of one Morse dash
symbol_gap = dot_length # Duration of gap between dot or dash
character_gap = (dot_length * 3.0) # Duration of gap between characters
flash_color = (255,0,0) # Color of the morse display.
brightness = 0.5 # Display brightness (0.0 - 1.0)
morse = [
('0', '-----'),
('1', '.----'),
('2', '..---'),
('3', '...--'),
('4', '....-'),
('5', '.....'),
('6', '-....'),
('7', '--...'),
('8', '---..'),
('9', '----.'),
# Define a class that represents the morse flasher.
class MorseFlasher:
def __init__(self, color=(255, 255, 255)):
# set the color adjusted for brightness
self._color = (
int(color[0] * brightness),
int(color[1] * brightness),
int(color[2] * brightness)
def light(self, on=True):
if on:
pixels.fill(self._color)
else:
pixels.fill((0, 0, 0))
pixels.show()
def showDot(self):
self.light(True)
time.sleep(dot_length)
self.light(False)
time.sleep(symbol_gap)
def showDash(self):
self.light(True)
#self.beep(True)
time.sleep(dash_length)
self.light(False)
def encode(self, string):
output = ""
# iterate through string's characters
for c in string:
# find morse code for a character
for x in morse:
if x[0] == c:
# add code to output
output += x[1]
# add a space in between characters
output += " "
# save complete morse code output to display
self.display(output)
def display(self, code=".-.-.- "):
# iterate through morse code symbols
for c in code:
# show a dot
if c == ".":
self.showDot()
# show a dash
elif c == "-":
self.showDash()
# show a gap
elif c == " ":
time.sleep(character_gap)
def rainbow(num):
for i in range(num):
cpx.pixels[0] = (255, 0, 0)
cpx.pixels[1] = (255, 85, 0)
cpx.pixels[2] = (255, 255, 0)
cpx.pixels[3] = (0, 255, 0)
cpx.pixels[4] = (34, 139, 34)
cpx.pixels[5] = (0, 255, 255)
cpx.pixels[6] = (0, 0, 255)
cpx.pixels[7] = (0, 0, 139)
cpx.pixels[8] = (255, 0, 255)
cpx.pixels[9] = (75, 0, 130)
time.sleep(0.5)
pixels.show()
time.sleep(0.3)
pixels = cpx.pixels
pixels.show()
# Create a morse flasher object.
flasher = MorseFlasher(flash_color)
cpx.play_file("lightsaber.wav")
# Main loop will run forever
while True:
if cpx.button_a:
cpx.play_file("coin.wav")
num = random.randrange(0,len(messageList))
message = messageList[num]
message = message.upper()
flasher.encode(message)
rainbow(3)
time.sleep(1)
elif cpx.button_b:
cpx.play_file("jump.wav")
try:
rainbow(3)
time.sleep(1)
except:
cpx.play_file("oops.wav")
- mikeysklar
Have you had any luck with adjusting the dot_length / dash_length while playing audio? I see you have moved from the default .15 to .2 would it help to go to .5 or even 1 second durations? Your symbol_gap is tied to dot_length so slowing everything down might make it clearer?
Another option is to explore the multitasking ability of CircuitPython. It is a more complicated setup to use asyncio, but you might be able to make things work.
https://learn.adafruit.com/cooperative- ... th-asyncio
This guide describes how to do cooperative multitasking in CircuitPython, using the asyncio library and the async and await language keywords. The asyncio library is included with CPython, the host-computer version of Python. MicroPython also supplies a version of asyncio, and that version has been adapted for use in CircuitPython.
Since play_tone is going to delay for the specified time, Why not just replace the sleep with a call to play_tone using the same duration. Something like:
def showDot(self):
self.light(True)
cpx.play_tone(262, dot_length)
self.light(False)
def showDash(self):
self.light(True)
cpx.play_tone(262, dash_length)
self.light(False)
Hi mikeysklar and adafruit_support_bill - thanks so much for taking the time to reply. I will consider both responses and let you know the outcome!
Best,
Arnie
Best,
Arnie
