Hi.
I know there is already an Adafruit Metro M7, but it's built with the NXP iMXRT MCU.
Of course, iMXRT is a very high-performance and wonderful core, as it is also used in Teensy4.
However, I felt the need for a version using the Microchip (Atmel) ATSAM MCU, which is highly compatible with conventional hardware and software.
So I'm thinking of making an ATSAME70 version of Metro M7.
Unfortunately, I don't have the experience or knowledge to do so.
So I would like to borrow your wisdom.
【What I know】
- Adafruit's ATSAM boards are built on the UF2 Bootloader ( https://github.com/adafruit/uf2-samdx1 )
- Tool for burning bootloader (bossa) supports ATSAME70 ( https://github.com/arduino/bossa )
- SAM-BA is a common low-level library for the ATSAM series, and UF2 is based on it (code generated by Atmel Start?)
【What I don't know】
- How to make UF2 compatible with ATSAME70 (part to edit after cloning adafruit/uf2-samdx1)
- MCU-specific information such as offsets when writing with bossa
Thanks.
I want to make Metro M7 version SAME70
- dojyorin
Re: I want to make Metro M7 version SAME70
[Task]
* First, I cloned adafruit/uf2-samdx1
* SVD file with register information is required
* Create a "SAME70" directory in "/lib" of the cloned repository and store the svd file
* Add source code for SAME70 about "startup_*.c", "init_*.c", "flash_*.c" in "/src"
<Cloned my repository>
https://github.com/dojyorin/uf2-same70
<SVD file>
https://www.keil.com/dd2/pack
<MCU datasheet>
https://ww1.microchip.com/downloads/aem ... 001527.pdf
<SVD file>
<MCU datasheet>
- dojyorin
Fortunately, I was able to obtain ATSAME70J21B in the shortage of semiconductors.
I would like to continue working with this.
