I can't even make the light blink right
- saobus83
good evening super new to electronics know zero about programing I was following the guide for the QT Py SAMD21 after getting through the update part you write a code to make a light blink well the blink the blink didn't change when I changed the time parts of the code
- bidrohini
Re: I can't even make the light blink right
Hi, have you followed this document?
https://learn.adafruit.com/adafruit-qt-py
- adafruit_support_carter
The Learn Guide linked above is the correct one to be following for that QT PY.
Are you trying to program the board using CircuitPython or Arduino?
- saobus83
I am using circuit python.
https://github.com/adafruit/Adafruit_Le ... on/code.py
I actually, found the solution here because the QT Py only has the neo pixel and no other LEDs so the code on the guide for the for the SAMD21 QT Py has a blink light code that you can't use, though I do remember using that same code with my SAMD21 Trinket M0 which makes since, they both use the same chip.
- Capture.JPG (54.55 KiB) Viewed 94 times
