I received a 1 x PoE Splitter with USB Type C - 5V 2A - 100 MB Ethernet[ID:4552] Order Confirmation No: 2973429-2712094547 today. I promptly tried to put it into use and when I opened a terminal and performed "ip address", then eth0 showed the error: "no carrier signal detected". I did extensive network trouble shooting including bypassing the splitter, which did give me a connection for my Raspberry Pi 400 to my network. I have a full Cat. 6/1Gbs network (switches and all cabling). How can we proceed?
Peter
PoE splitter no carrier signal detected
- mikeysklar
Re: PoE splitter no carrier signal detected
I've had one issue with the PoE have a soldering issue. If you want to open it up and check the solder points to confirm everything is well connected you are welcome to do so. Otherwise we can replace or refund you.
viewtopic.php?p=889262
- PeterPrime
I would prefer the refund option. Thank you. How do we get that started?
What is incumbent upon me to get this started?
Peter
Peter
- mikeysklar
Please send an e-mail [email protected] for a refund. They will need this forum link and your order#.
- PeterPrime
Thank you, Mikey Sklar.
