Can you successfully program the board via the Arduino IDE per the guide?
https://learn.adafruit.com/adafruit-fea ... e/overview
Feather 32u4 with LoRa Radio Module
- adafruit_support_carter
- Reylan
Re: Feather 32u4 with LoRa Radio Module
Nope, it doesn't show as a USB to serial device
Is the red LED also not blinking as expected after pressing reset? (same check as done on other boards)
- Reylan
Nope, led doesn't blink.
- Reylan
i guess as i tried to wire mosi/miso/sck/reset/gnd/usb and try to program the board with a uno with the arduino as isp sketch, there is no much hope...
Let's just replace it again. Try uploading a basic Blink sketch before doing anything else just to make sure it's at least arriving OK.
Reply in email back to [email protected] and link them again here and they can send you another Feather 32u4 LoRa.
- Reylan
I sent an email to support, they told me to come back to you to check the number of malfunctionning parts.
I can tell you that from the first order, i've been able to save one feather. On the second, 5 of them came without bootloader and i haven't been able to flash them.
Were are only dealing with the second order at this point? Replacements were sent for the issues with the first order?
First order = the one mentioned in first post. Did you get replacements for that?
Second order = the one mentioned later after first order replacements were authorized.
- Reylan
Hope we was good !
First order, no replacment. I saved one, the other is still not functionning.
Second order, as said, 5 are not ok.
I'm about to make a third order with more feather lora. Hope that probleme will be fixed in the meantime.
So, what should i do to move forward ? Get in touch with support again ?
Hope we was good !
OK, it sounds like 1 bad one from first order and 5 bad ones from a second order.
It sounds like you never sought a replacement on the first order, even though that was authorized several posts ago in this thread (2002/12/12).
Yes, please email [email protected] again and link them to this form post. They can send you 6 replacement Feather 32u4 LoRas.
