Adafruit ItsyBitsy nRF52840 Express - Not working
- bobzai2015
I have an Adafruit ItsyBitsy nRF52840 Express. In the first few days of playing with the microcontroller, I would upload code from the Arduino IDE and the code would be on-board. The red LED on the board would be glowing, indicating that the board was on/powered and that BLE was enabled. However, recently, I have tried uploading code and after uploading the new code, the LED powers off, despite being connected to the computer. When I disconnect from the computer and power with an external power supply, the LED no longer turns on.
- adafruit_support_carter
Re: Adafruit ItsyBitsy nRF52840 Express - Not working
Can you get the basic Blink example to work?
#if defined(USE_TINYUSB)
#include <Adafruit_TinyUSB.h> // for Serial
#endif
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
- bobzai2015
Hi, yes the Blink script works - the BLE LED is also on. The code we are trying to run on the microcontroller is below:
Is it possibly the USB stack?
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 5, 7, 9, 10);
// set the speed at 60 rpm:
myStepper.setSpeed(160);
// initialize the serial port:
pinMode(5, OUTPUT);
pinMode(7, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
digitalWrite(11, HIGH);
digitalWrite(12, HIGH);
// step one revolution in one direction:
myStepper.step(stepsPerRevolution);
delay(500);
// step one revolution in the other direction:
myStepper.step(-stepsPerRevolution);
delay(500);
Which LED are you referring to here? There's nothing in your example code that is driving an LED.However, recently, I have tried uploading code and after uploading the new code, the LED powers off, despite being connected to the computer.
- bobzai2015
Sorry, I was referring to the BLE LED.
Is your code working OK otherwise? It looks like it's driving a stepper motor. Since the code is not doing anything specific with the LEDs, then don't worry about what the LEDs are doing / not doing.
- bobzai2015
The issue is that when the board's BLE LED is off (even when powered and no bluetooth code is being implemented), the board has to be reset before I can upload code again.
There are times when I have uploaded BLE-code (like the code below [modified from example code]) and the board will work, but then other times when the same exact code causes the board to become unresponsive (not working and BLE LED is off, needs to be reset). Is this a common occurrence? Is it possible this has to do with how I am uploading the code?
This is an example for our nRF52 based Bluefruit LE modules
Pick one up today in the adafruit shop!
products from Adafruit]\
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in
any redistribution
#include <bluefruit.h>
// OTA DFU service
BLEDfu bledfu;
// Uart over BLE service
BLEUart bleuart;
// Function prototypes for packetparser.cpp
uint8_t readPacket (BLEUart *ble_uart, uint16_t timeout);
float parsefloat (uint8_t *buffer);
void printHex (const uint8_t * data, const uint32_t numBytes);
// Packet buffer
extern uint8_t packetbuffer[];
void setup(void)
Serial.begin(115200);
while ( !Serial ) delay(10); // for nrf52840 with native usb
Serial.println(F("Adafruit Bluefruit52 Controller App Example"));
Serial.println(F("-------------------------------------------"));
Bluefruit.begin();
Bluefruit.setTxPower(4); // Check bluefruit.h for supported values
// To be consistent OTA DFU should be added first if it exists
bledfu.begin();
// Configure and start the BLE Uart service
bleuart.begin();
// Set up and start advertising
startAdv();
Serial.println(F("Please use Adafruit Bluefruit LE app to connect in Controller mode"));
Serial.println(F("Then activate/use the sensors, color picker, game controller, etc!"));
Serial.println();
pinMode(7, OUTPUT);
void startAdv(void)
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
// Include the BLE UART (AKA 'NUS') 128-bit UUID
Bluefruit.Advertising.addService(bleuart);
// Secondary Scan Response packet (optional)
// Since there is no room for 'Name' in Advertising packet
Bluefruit.ScanResponse.addName();
/* Start Advertising
* - Enable auto advertising if disconnected
* - Interval: fast mode = 20 ms, slow mode = 152.5 ms
* - Timeout for fast mode is 30 seconds
* - Start(timeout) with timeout = 0 will advertise forever (until connected)
* For recommended advertising interval
* https://developer.apple.com/library/content/qa/qa1931/_index.html
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
@brief Constantly poll for new command or response data
void loop(void)
// Wait for new data to arrive
uint8_t len = readPacket(&bleuart, 500);
if (len == 0) return;
// Got a packet!
// printHex(packetbuffer, len);
// Color
if (packetbuffer[1] == 'C') {
uint8_t red = packetbuffer[2];
uint8_t green = packetbuffer[3];
uint8_t blue = packetbuffer[4];
Serial.print ("RGB #");
if (red < 0x10) Serial.print("0");
Serial.print(red, HEX);
if (green < 0x10) Serial.print("0");
Serial.print(green, HEX);
if (blue < 0x10) Serial.print("0");
Serial.println(blue, HEX);
// Buttons
if (packetbuffer[1] == 'B') {
uint8_t buttnum = packetbuffer[2] - '0';
boolean pressed = packetbuffer[3] - '0';
Serial.print ("Button "); Serial.print(buttnum);
if (pressed) {
Serial.println(" pressed");
if (buttnum == 5){
digitalWrite(7, HIGH);
digitalWrite(11, LOW);
} else if (buttnum == 6){
digitalWrite(7, LOW);
} else {
} else {
Serial.println(" released");
// GPS Location
if (packetbuffer[1] == 'L') {
float lat, lon, alt;
lat = parsefloat(packetbuffer+2);
lon = parsefloat(packetbuffer+6);
alt = parsefloat(packetbuffer+10);
Serial.print("GPS Location\t");
Serial.print("Lat: "); Serial.print(lat, 4); // 4 digits of precision!
Serial.print('\t');
Serial.print("Lon: "); Serial.print(lon, 4); // 4 digits of precision!
Serial.print('\t');
Serial.print(alt, 4); Serial.println(" meters");
// Accelerometer
if (packetbuffer[1] == 'A') {
float x, y, z;
x = parsefloat(packetbuffer+2);
y = parsefloat(packetbuffer+6);
z = parsefloat(packetbuffer+10);
Serial.print("Accel\t");
Serial.print(x); Serial.print('\t');
Serial.print(y); Serial.print('\t');
Serial.print(z); Serial.println();
// Magnetometer
if (packetbuffer[1] == 'M') {
float x, y, z;
Serial.print("Mag\t");
// Gyroscope
if (packetbuffer[1] == 'G') {
float x, y, z;
Serial.print("Gyro\t");
// Quaternions
if (packetbuffer[1] == 'Q') {
float x, y, z, w;
w = parsefloat(packetbuffer+14);
Serial.print("Quat\t");
Serial.print(z); Serial.print('\t');
Serial.print(w); Serial.println();
The on/off state of the LED is potentially a red herring. Since nothing in the code is directly controlling the pin the LED is attached to, its behavior is coincidental.
Sometimes the running sketch can get in a bad state which does cause the board to become unresponsive to new uploads. The sketch being in a bad state prevents the board from being software reset to reset to accept a new sketch upload. Manually resetting is the work around for this.
But that does not determine why the original sketch got in a bad state in the first place. Determining that can be tricky. See if you can better correlate when the board gets in that state with a given sketch. Ideally, see if you can come up with the smallest simplest sketch that can demonstrate the issue.
- bobzai2015
The code I posted above is from the BLE example library and doesn't pose problems on its own. When I add in the digitalWrite lines, however, we sometimes experience problems and sometimes do not have issues. Is there something about digitalWrite for the ItsyBitsy firmware that is not compatible?
If the problems only occur "sometimes" then it can be tricky to determine the cause. It helps to be able to somehow determine a correlation with something. There's weak correlation to usage of digitalWrite. However, there generally should not be any issue using that method. So it may be related, but the real issue is something else.
