Trace wire patch points for vr3
Discuss x0x construction and related issues
Moderators: altitude, adafruit_support_bill, adafruit, hamburgers, phono
gujo
Post by gujo »
While playing around with different values on q8, q9 and q10 I also replaced vr3. This has been replaced many times over the years on my old beaten x0x and I believe that this time the soldering points at the pcb was damaged.
I managed to find a patch point for the right pin on vr3 but turning the knob does not affect cutoff freq at all, could anyone recommend patch points for the 2 other pins?
gujo
Re: Trace wire patch points for vr3
Post by gujo »
I managed to solve this with a multimeter and some help from looking at pictures of unfinished x0x pcb:s.
oer23
Post by oer23 »
If you look the schematic you can see that VR3 pin1 is connected to +12V (emitter pin of Q27), VR3 center pin to pin3 of TM3 and VR3 pin 3 to R47.
Cheers.
Return to “Making x0x”
