SPI Perpheral read
- JPF100
SPI Perpheral read
I am now working on simple SPI interface. I have 2 GCs connected in a master/slave or controller/peripheral configuration. I am using the Arduino environment. I have been able to transmit from the controller to the peripheral, but I want to be able to read the transmitted byte from the controller on the peripheral side and display it on the peripheral's serial port console. I setup the peripheral using a series of SERCOM1 commands. This setup enables interrupts on the peripheral side of things. I successfully read back the data on the controller side. I confirmed that all of the lines are setup correctly with an oscilloscope. I also confirmed with a scope that the data being transmitted back to the controller is correct on the CIPO line with the clock. Working Arduino M4 C++ code example for the controller and peripheral along with specific pinouts for both sides would be appreciated.
