To whom it may concern,
Hello. I have a question about how to smooth out the noise/messy signal using a capacitor when it comes to controlling a joystick with an Arduino.
The link is pasted down below to view a photo. There are three photos within a link; Arduino/joystick diagram, photo, and signal wave.
LINK : https://imgur.com/a/dARk6hX
As you can know, the signal is not always constant as shown in one of the photos. The signal is received by a pin A4 (Analog Pin) on Arduino Mega.
My goal here is to get rid of the unstable-messy signal wave and to smooth it out using a capacitor.
Does anyone have any ideas on how to wire a capacitor to smooth out the messy signal? And also, what type of capacitor should I use?
If someone could paste the diagram on how to wire a capacitor and also show an electrical calculation with a detailed explanation, that would be very helpful.
Best Regards,
Alex
[Arduino Circuit Question] Using a Capacitor to Smooth Out the Messy Noise or Unstable Signal
- AlexUAS
Re: [Arduino Circuit Question] Using a Capacitor to Smooth Out the Messy Noise or Unstable Signal
Software filtering is usually a simpler and more flexible approach: https://www.megunolink.com/articles/cod ... surements/
- languer
The joystick you show seems like this one: https://www.adafruit.com/product/512
What is the waveform you show of? - it doesn't look like an analog one.
The following example shows a basic example of this: https://learn.adafruit.com/pro-trinket- ... tick-mouse
You could take some ideas from that. A capacitor (to ground) at the Xout and one at the Yout pins will certainly smooth out the waveform, but the waveform you showed looks more like a serial (or pwm) signal than it does an analog one so I am not sure what you are really seeing. And as Bill suggested, software filtering may be a better option, if you end up needing to. The following section on the example above provides you some real-life example of how to "filter" the analog reading:
// Reads a joystick axis (0 or 1 for x or y) and scales the
// analog input range to a range from 0 to <range>
int readAxis(int thisAxis) {
int reading = analogRead(thisAxis); // read the analog input
// map the reading from the analog input range to the output range
reading = map(reading, 0, 1023, 0, range);
// if the output reading is outside from the rest position threshold, use it
int distance = center - reading;
if (abs(distance) < threshold) { // if distance not to threshold, no move
distance = 0; // prevents tiny jitters due to readings
return distance; // return the distance for this axis
