Hey there wonderful community!
I have an ItsyBitsy M0 Express, that I used about a month back. But in hooking it up yesterday to reprogram, it is no longer generating a COM port, so the Arduino IDE won't talk to it.
I know the USB cable and port work, because I can plug in my Metro Express and it works just fine. But, when I connect the ItsyBitsy, I get a Windows message that "USB Device not recognized," and then there is no COM port in the Arduino IDE, either in the automatic dropdown or when I select the ItsyBitsy directly from the "Select Other Board and Port" menu.
I wonder if the trouble is that I just updated to the Arduino IDE version 2.0.3, so perhaps I should post this in the Arduino forums as well?
Finally, I am using Windows 11 Home, on an Alienwaer x17 R2. Nothing unusual or fancy about the setup.
Any guidance would be appreciated, and thank you again for your support of this great product!
I am including a picture here of my previous ItsyBitsy project, because it's cool.
ItsyBitsy M0 no longer working
- IanLukeFinley
- unnamed.jpg (206.6 KiB) Viewed 179 times
- Franklin97355
Re: ItsyBitsy M0 no longer working
If Windows does not see the USB Device then software won't either. The problem is between windows and the itsybitsy not arduino. I don't know of a fix but I will ask.
- adafruit2
check the https://learn.adafruit.com/introducing- ... tsy-m0/faq
Ack! I "did something" and now when I plug in the Itsy/Feather, it doesn't show up as a device anymore so I cant upload to it or fix it...
- IanLukeFinley
This certainly looks like the issue I'm dealing with, but when I follow the steps in that article, verbose does not produce a list of attempted COM ports (see image), and double clicking the reset doesn't activate the red LED or put it into bootloader mode (although I do get the "USB Device Not Recognized" Windows alert, so the reset is happening).adafruit2 wrote: ↑Sat Dec 17, 2022 7:25 pm check the https://learn.adafruit.com/introducing- ... tsy-m0/faq
Any other process I could try?
- adafruit2
maybe try some other USB cables? doubleclicking should def get you into bootloader mode, unless it somehow got damaged :/
- Franklin97355
Also make sure you have verbose on the uploading too.
- IanLukeFinley
Cables are just evil. The cable I was using worked just fine with my Metro board, but turns out it was the issue with the ItsyBitsy. Used another cable, and the bootloader trick worked. Thank you all for your patience and help, I'm so excited to finish out this project this weekend!
- adafruit2
