Voice Bonnet not playing audio
cfernandezruns
Post by cfernandezruns »
I recently purchased a Voice Bonnet https://learn.adafruit.com/adafruit-voice-bonnet and I'm having trouble getting audio with my Raspberry Pi CM4 IO Board.
I completed the installation instructions for a headless Raspbian Lite install (2022-09-22 release).
Following the instructions, I logged in via ssh, and completed the installation steps.
I do see the Voice Bonnet listed with the UU flag at address 1a.
I do see the Voice Bonnet listed as a sound card:
pi@raspberrypi:/etc $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0]
  Subdevices: 1/1
The next step is to run speaker-test -c2. When I do this, I get no audio output at all. I have the two Adafruit-recommended speakershttps://www.adafruit.com/product/4445 connected to the voice bonnet. I've also tried plugging in a pair of headphones to the headphone jack - no audio there, either.
Are there additional steps that must be completed to get ALSA to play something out of the new sound card?
mikeysklar
Re: Voice Bonnet not playing audio
Post by mikeysklar »
How about a more specific speaker test that is direct at card 2 device 0 based on the aplay output.
speaker-test -c 2 -F S16_LE -r 48000 -D hw:2,0
cfernandezruns
Hi mikeyskylar, thanks for the quick response.
I ran the command you suggested. Still not getting audio, but I was able to do some quick checks with my oscilloscope. When running your command, I can see data flowing on DOUT/pin 40/BCM GPIO 21. I can also see the LRCLK running on pin35/BCM GPIO 19. These are both 3.3V signals.
The signal that looks weird to me is BCLK. I was expecting to see a 48kHz, 3.3V clock. But instead, I'm seeing a ~2.0V DC line. When I stop the speaker-test, the BCLK line stays at 2.0V.
I'm wondering if this means there is an I/O conflict or something? Could another peripheral be enabled that is preventing BCLK from working properly?
Yellow = BCLK
Blue = DOUT
Pink = LRCLK
mikeysklar
Nice. Thanks for the scope shot.
Good thought on another driver possibly causing a conflict.
Try going over the "Detailed Install" section to review the changes that the i2samp script was applying. Another forum user recently reported having to skip the i2samp script entirely and do the manual install by hand suggesting that the i2samp script has lost some compatibility with the current Bullseye release.
https://learn.adafruit.com/adafruit-spe ... ll-2712959
viewtopic.php?p=948803&hilit=voice+bonnet#p948803
cfernandezruns
The instructions you linked are for the Adafruit Speaker Bonnet, based on the MAX98357 amplifier.
I'm working with the Adafruit Voice Bonnet, which is based on the WM8960 audio codec.
I'm assuming that this is a typo. Correct? Or, is there something in the Speaker Bonnet manual instructions that also applies to the Voice Bonnet?
cfernandezruns
Some more digging....
I can run the script with the Voice Bonnet removed from the headers. I can still see LRCLK and DOUT flowing, and BCLK is still stuck at ~2.0V.
This means that the unusual BCLK behavior is not related to the Voice Bonnet hardware itself. It could be a problem with my hardware, or it could be some kind of software configuration issue with the RPi/Voice Bonnet software running on my Compute Module 4.
According to page 50 of the WM8960 datasheet, BCLK and LRCLK must be provided by the host processor if the codec is operating in Slave mode (which I'm pretty sure it is, given the presence of LRCLK even with the Voice Bonnet removed). So, I'm pretty sure that the missing BCLK is why I'm not getting audio flowing.
Can you confirm that the Voice Bonnet software is intended to operate with the RPi in I2S Master mode?
cfernandezruns
Update:
I tried switching to a second Compute Module 4 to see if I had a hardware issue with my module. Turns out, I did!
I re-installed everything according to the setup guide on the second CM4. On this board, the speaker-test command posted above gave me static immediately, alternating between the left and right speaker outputs on the Voice Bonnet.
The issue is now closed. I appreciate the help!
mikeysklar
Thank you for trying another Pi and going through the installation again. Glad to hear that resolved it.
