Trouble with the adafruit IO circuitpython Basic example
ablesser
Post by ablesser »
Hi folks, I'm trying to learn/use circuitpython on a Raspberry pi Pico W, following this tutorial: https://learn.adafruit.com/pico-w-wifi- ... dafruit-io
While the code runs, and data uploads.. it's not at all reliable.. and every so many data transmissions I have my board bomb out and reset (that is, the code hits the exception block) below:
I know the problem isn't in the setup code / wifi, because that always connects reliably. When it bombs, I get "Error:" ... but nothing after error... totally blank.
No errors are showing up on the monitor in adafruit IO either (https://io.adafruit.com/BANNED/monitor).
Suggestions ? I tried increasing / decreasing the time.sleep(1) in the example code below... I noted that removing it entirely seems to cause the board to crash more.. but increasing it past (1) doesn't seem to do anything.
while True:
    try:
        #  when the clock runs out..
        if clock > 300:
            #  read sensor
            data = [aht20.temperature, aht20.relative_humidity]
            #  send sensor data to respective feeds
            for z in range(2):
                io.send_data(feed_names[z]["key"], data[z])
                print("sent %0.1f" % data[z])
                time.sleep(1)
            #  print sensor data to the REPL
            print("\nTemperature: %0.1f C" % aht20.temperature)
            print("Humidity: %0.1f %%" % aht20.relative_humidity)
            print()
            time.sleep(1)
            #  reset clock
            clock = 0
        else:
            clock += 1
    # pylint: disable=broad-except
    #  any errors, reset Pico W
    except Exception as e:
        print("Error:\n", str(e))
        print("Resetting microcontroller in 10 seconds")
        time.sleep(10)
        microcontroller.reset()
    #  delay
    time.sleep(1)
    print(clock)
adafruit_support_carter
Re: Trouble with the adafruit IO circuitpython Basic example
Where are you seeing that?
hyde00001
Post by hyde00001 »
I can’t even get as far as you with my Pi Pico W setup. Can you list which version of Circuit Python and libraries you are/were using??
