KB2040 will not work after power cycle
For Adafruit customers who seek help with microcontrollers
slammers
Post by slammers »
I purchsed 5 KB2040 for a project and one of them is acting odd. I am programming using the C/C++ SDK. When I put the device into boot mode and copy over the program, it works just find. But after power cycling it appears dead.
If I then put it back into boot mode and copy over the UF2 file again, it works fine.
I tried this with a very siumple blink program and it has the same symptoms.
Does anyone know why it would not function from a cold boot? Does it have defective flash?
adafruit_support_carter
Re: KB2040 will not work after power cycle
Is the behavior unique to using the C/C++ SDK? Do you see similar behavior using Arduino?
slammers
Post by slammers »
I have never tried arduino.
I can try the Python interpreter I guess. Or is that what you mean?
Yep, or CircuitPython. Idea is to just test with something else to help determine if it's something specific to the C/C++ SDK usage or elsewhere.
slammers
Post by slammers »
Micropython has the same result.
I program it and Thonny connects just fine and I can run code and save to flash.
Press the reset button and Thonny will not longer connect
Power cycle, Thonny will not connect
Re-install Python, Thonny connects
I can then load the code that I had saved to the Pico with thonny and run it.
Press reset button and its dead again.
Weird. And that behavior is specific to only 1 out of 5 total KB2040's?
slammers
Post by slammers »
Yes, only one has this problem.
OK, try this blink test UF2. Put the KB2040 in bootloader mode and drag the UF2 to the RPI-RP2 folder. It should blink the onboard NeoPixel.
Is it still doing the same thing?
KB2040_NEO_BLINK.UF2
(131.5 KiB) Downloaded 15 times
slammers
Post by slammers »
Ok so that is odd. That program survives a reset.
So I re-installed my blink program that does basically the same thing and it does not survive a reset.
I installed the micro python interpreter, it also again does not survive a reset.
Re-installing the Adafuit blinky program, it does survive a reset.
What could be the difference?
Not sure. Weird behavior. Esp since it's specific to only 1 of the KB2040s.
This is the Raspberry Pi's Pico SDK?
https://github.com/raspberrypi/pico-sdk
Are you doing anything unique in terms of build environment, compiling, etc?
Return to “Microcontrollers”
