I am a beginner in Arduino and recently bought a Huzzah32 Feather. I'm trying to set it up with adafruit IO. So I follow the steps and proceeded to the "https://adafruit.github.io/WipperSnappe ... _Uploader/" page. I then select my board and fill out the correct wifi information, my IO username, and my IO key. The problem occurs when I click "install WipperSnapper". The installation gets stuck right away on "Erasing Flash (1/3)...", and is stuck for hours.
I have tried different USB cables even though I know they do work. I have also tried holding the reset button.
The console output:
Wippersnapper Firmware Uploader loaded.
Connecting...
Connected successfully.
Try hard reset.
Chip type ESP32
Connected to ESP32
MAC Address: 8C:4B:14:0E:F0:24
Uploading stub...
Running stub...
Stub is now running...
Detecting Flash Size
FlashId: 0x164020
Flash Manufacturer: 20
Flash Device: 4016
Auto-detected Flash size: 4MB
Attempting to change baud rate to 115200...
Fetching latest firmware...
Unzipping firmware bundle...
Flashing with settings:
"files": [
"filename": "secrets.json"
"rootFolder": "files",
"fileSystemSize": 1507328,
"blockSize": 4096,
"offset": 2686976,
"chip": "esp32",
"flashMode": "dio",
"flashFreq": "80m",
"flashSize": "4MB",
"structure": {
"0": "wippersnapper.feather_esp32.littlefs.1.0.0-beta.57.combined.bin"
Changed baud rate to 115200
Problems with installing WipperSnapper
- brubell
- Learn User Page
Re: Problems with installing WipperSnapper
Looks similar to this thread, viewtopic.php?p=953279#p953279
I'm unable to replicate this on my computer. Could you try another USB cable? If that doesn't work, could you try doing this on another computer?
