after a year I got back to working with the Trinkey, but things have changed, at least as I'm using a Mac M1 Pro now. I tried to install the Arduino SAMD boards, but they can't be installed using the Arduino IDE. With a manual install I get "bad CPU type" as a result, I guess the boards are not updated to work with the M1 Pro yet?
Am I wrong, is there a workaround? Any ideas? Thanks!
Hans
Trinkey SAMD Board can't be installed
- mikeysklar
Re: Trinkey SAMD Board can't be installed
Which version of the Arduino IDE are you using? What version of MacOS?
I believe the M1 builds showed up in the 2.0.1 Arduino IDE snapshots.
https://github.com/arduino/arduino-ide/pull/933
- hanstammen
Hi, thanks for the feedback! I do not know which part solved it, but I updated everything and one them them has done the trick. Eventually it worked. Thanks!
- mikeysklar
Yeah, you definitely need to be on the newer Ardiuno IDE and libraries for M1 Pro support. I think support was added starting in the Spring of 2022. Glad you are up and running.
