CP Bluefruit no sound after reset
Play with it! Please tell us which board you're using.
lukagra
Post by lukagra »
My daughter got her Circuit Playground Bluefruit. She’s playing with it with MakeCode Maker editor. I know support is still in beta but just wanted to let you know what we see. She’s all very exited but there is some issue with sound output. It plays ok only right after putting the code on the device. After a reset (or power cycle) the speaker just makes a silent buzz. You can see and hear it on the clip I’ve made
https://share.icloud.com/photos/049uMKD ... uU1Po2lLcg
Any ideas why this happens? Can we fix it with upgrade or something?
The code generated it like this
 def on_button_b_long_click():
    music.set_volume(125)
    music.power_up.play_until_done()
    if input.button_b.was_pressed():
        pause(1000)
        light.set_brightness(25)
        light.set_all(0x007fff)
        pause(1000)
        light.set_all(0x7f00ff)
        pause(1000)
        light.set_all(0xff00ff)
        pause(1000)
        light.set_all(0xff9da5)
        pause(1000)
        light.set_brightness(0)
input.button_b.on_event(ButtonEvent.LONG_CLICK, on_button_b_long_click)
def on_button_a_click():
    light.set_brightness(20)
    light.default_strip().set_gradient(0xff0000, 0xffff00)
    music.play_melody("B A G A A B G B ", 450)
    music.play_melody("F E D E E F D F ", 450)
input.button_a.on_event(ButtonEvent.CLICK, on_button_a_click)
def on_gesture_shake():
    def on_run_in_parallel():
        music.play_melody("G A A G A B B A ", 240)
        light.default_strip().set_pixel_color(0, 0xff0000)
        pause(100)
        light.default_strip().set_pixel_color(1, 0xff8000)
        pause(100)
        light.default_strip().set_pixel_color(2, 0xffff00)
        pause(100)
        light.default_strip().set_pixel_color(3, 0xff9da5)
        pause(100)
        light.default_strip().set_pixel_color(4, 0xb09eff)
        pause(100)
        light.default_strip().set_pixel_color(5, 0x7f00ff)
        pause(100)
        light.default_strip().set_pixel_color(6, 0xff00ff)
        pause(100)
        light.default_strip().set_pixel_color(7, 0xff0080)
        pause(100)
        light.default_strip().set_pixel_color(8, 0xff8000)
        pause(100)
        light.default_strip().set_pixel_color(9, 0xff0000)
        pause(2000)
    control.run_in_parallel(on_run_in_parallel)
input.on_gesture(Gesture.SHAKE, on_gesture_shake)
mikeysklar
Re: CP Bluefruit no sound after reset
Post by mikeysklar »
Does it make a difference if the USB is disconnected and run off the battery?
Ditto for vice-versa. USB connected and battery disconnected?
lukagra
Post by lukagra »
No, it's the same regardless of connections. The only way to make it work is to connect baterry and USB, put new code file, turn on battery and disconnect usb. But this lasts till turn off.
lukagra
Post by lukagra »
I’ve checked that using original code file from here
https://cdn-learn.adafruit.com/assets/a ... 1620059549
does work ok! Speaker works ok after multiple reset or turning off. So it’s a problem with Maker code, right?
mikeysklar
Yes, the test comparing stock code to your modified MakeCode is a great one. Something about the customized code is causing the sound not to come back.
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
