L3GD20 (3DOF) bandwidth with CircuitPython
For Adafruit customers who seek help with microcontrollers
Thomas_G_S
Post by Thomas_G_S »
I am trying to increase the bandwidth of the L3GD20 3DOF sensor using a Raspberry Pi Pico running CircuitPython, but I can't find the command. I don't need more updates per second, I am trying to increase the communication bandwidth to decrease the gyro latency. Can anyone help me?
mikeysklar
Re: L3GD20 (3DOF) bandwidth with CircuitPython
Post by mikeysklar »
Are you connecting to it via SPI or I2C?
Thomas_G_S
I'm using SPI. Would I be correct in saying that SPI will have a lower latency.
mikeysklar
SPI is the right choice for speed / latency concerns.
The SPI clock can be adjusted. Maybe start with 24MHz and try up to 62.5MHz with a Pico to see what you can measure.
>>> spi.configure(baudrate=5000000, phase=0, polarity=0)
Thomas_G_S
I've tried adding that line into my code and I'm now getting an error: "RuntimeError: Function requires lock". Do you know what this means? Thanks!
Thomas_G_S
Ok, I've now got rid of the "Function Requires Lock" error. Problem is, the code is now stopping running here, as if in an empty while True loop:
from time import sleep
import time
import board
import digitalio
import busio
import adafruit_l3gd20
PI = 3.14159
# Initialize the SPI bus
spi = busio.SPI(board.GP18, MOSI=board.GP19, MISO=board.GP16)
# Initialize the CS pin
cs = digitalio.DigitalInOut(board.GP17)  # Replace D5 with the pin you are using for CS
cs.direction = digitalio.Direction.OUTPUT
# Initialize the L3GD20 gyroscope
l3gd20 = adafruit_l3gd20.L3GD20_SPI(spi, cs)
while not spi.try_lock():
    pass
# Setting spi frequency
spi.configure(baudrate=1000000, phase=0, polarity=0)
print("Gyro frequency has been set")
"""The code is currently stopping running here"""
# Read the gyroscope data (raw data is in radians per second)
while True:
    start = time.monotonic()
    # Getting raw gyroscope values and converting to degrees per second
    x = l3gd20.gyro[0] * (180/PI)
    y = l3gd20.gyro[1] * (180/PI)
    z = l3gd20.gyro[2] * (180/PI)
    print("X: " + str(x) + "Y: " + str(y) + "Z: " + str(z))
    end = time.monotonic()
    print(end - start)
    sleep(10)
Also, when I stop the program manually my computer stops being able to detect the Pico and I have to unplug it and reconnect before running the program again.
Thomas_G_S
I just tried this. Still no luck.
import time
import board
import digitalio
import busio
PI = 3.14159
    pass
    pass
    try:
        cs.value = False
        result = bytearray(4)
        spi.readinto(result)
        cs.value = True
    finally:
        spi.unlock()
while True:
    print(end - start)
    sleep(10)
mikeysklar
Let's try slower with less parameters and make sure you are seeing correct return from spi.frequency:
spi.configure(baudrate=250000)
spi.frequency
Does the code still stop in the same place?
Thomas_G_S
Thank you, it's working now!! I'm now just using this code, and it's now working at a frequency if 5 MHz:
    pass
spi.configure(baudrate = 5000000)
spi.frequency
spi.unlock()
Return to “Microcontrollers”
