Recently, I bought a motor driver and stepper motor only to realize the driver wasn't rated for the required current of my motor. Before I buy a new driver, I would like to be extra sure my setup is sound! Links to my proposed setup are below:
Stepper motor
Driver
This will be used with a Raspberry Pi 3 Model B V1.2 and a power supply that delivers 12V at 2A.
Additional questions:
1. Is there a way I can calculate the RPM of my stepper with this setup? Keep in mind the 51:1 gearbox.
2. Are there any Python libraries that allow for easy interfacing with this stepper driver?
Is My Stepper Motor and Driver Compatible?
- JJMoney
Re: Is My Stepper Motor and Driver Compatible?
The Amazon link for your motor does not work. However, the current limiting on the Pololu driver is adjustable, so it should work with a wide variety of motors.Before I buy a new driver, I would like to be extra sure my setup is sound! Links to my proposed setup are below:
The motor specs should tell you how many steps per revolution for the motor (for a 1.8 degree motor, that will be 200 steps).1. Is there a way I can calculate the RPM of my stepper with this setup? Keep in mind the 51:1 gearbox.
Multiply that by your gearbox ratio to get the number of steps per revolution of the output shaft (e.g 200 * 51 = 10200).
The final RPM will be the number of steps per second times 60, divided by the steps per revolution.
There are a few Python stepper libraries out there. We don't have any firsthand experience with the driver you are using. But the folks at Pololu may be able to point you to one that is known to work with their board.2. Are there any Python libraries that allow for easy interfacing with this stepper driver?
- JJMoney
Sorry, I fixed the link! This stepper looks like a 1.8 degree motor (without the gearbox). 10,200 steps per revolution seem correct with the gearbox then. Is steps per second a common metric found on stepper datasheets? I don't see it listed.adafruit_support_bill wrote: ↑Mon Dec 26, 2022 4:48 pmThe Amazon link for your motor does not work. However, the current limiting on the Pololu driver is adjustable, so it should work with a wide variety of motors.Before I buy a new driver, I would like to be extra sure my setup is sound! Links to my proposed setup are below:
The final RPM will be the number of steps per second times 60, divided by the steps per revolution.There are a few Python stepper libraries out there. We don't have any firsthand experience with the driver you are using. But the folks at Pololu may be able to point you to one that is known to work with their board.2. Are there any Python libraries that allow for easy interfacing with this stepper driver?
The steps per second is whatever you program it to be. The maximum achievable step rate for your system will depend on a number of factors, including motor, driver and power supply characteristics, as well as the load you have attached to the output shaft.
- JJMoney
I see. Is there any way I can calculate the maximum step rate for my system? I know the required torque to perform the job is ~400 oz-in and I'll be supplying 12V at 2A. With these in mind, could I at least ball-park the maximum achievable step rate?adafruit_support_bill wrote: ↑Mon Dec 26, 2022 5:06 pm The steps per second is whatever you program it to be. The maximum achievable step rate for your system will depend on a number of factors, including motor, driver and power supply characteristics, as well as the load you have attached to the output shaft.
Stepper motor torque decreases with increasing step-rate. A complete manufacturer's motor spec will typically include a torque vs. step-rate graph. This will be calculated at a specific supply voltage. Lower voltages will result in less torque and a slower top-speed.Is there any way I can calculate the maximum step rate for my system?
- JJMoney
One thing I'm a bit confused about when I look at this motor's torque curve is that the pull-out torque seems much higher than the motor's holding torque and max. permissible torque. Shouldn't the holding torque be the highest? Holding torque is the load the motor can support when it's not moving, correct? If I want to be sure of the torque this motor can handle when moving, which number should I be looking at?adafruit_support_bill wrote: ↑Mon Dec 26, 2022 7:23 pmStepper motor torque decreases with increasing step-rate. A complete manufacturer's motor spec will typically include a torque vs. step-rate graph. This will be calculated at a specific supply voltage. Lower voltages will result in less torque and a slower top-speed.Is there any way I can calculate the maximum step rate for my system?
Motor specs are sometimes ambiguous and often confusing. In this case, I suspect that the "Max Permissible Torque" is a property of the gearbox - not the motor itself.
The mechanical advantage of the gear reduction multiplies the raw torque of the motor. And with a 51:1 ratio, it is likely that the motor is capable of producing more torque than the output shaft can safely handle.
- JJMoney
Makes sense! So should I just assume that the 4Nm torque is what my motor is overall capable of?adafruit_support_bill wrote: ↑Mon Dec 26, 2022 8:03 pm Motor specs are sometimes ambiguous and often confusing. In this case, I suspect that the "Max Permissible Torque" is a property of the gearbox - not the motor itself.
That would be a reasonable assumption.
