Order 662714 12/10/2022
Just got this yesterday.
Soldered one speaker pin and one trigger switch.
Plugged into computer with previously tested data compatible USB cable.
Green and red lights are on, computer does not see sound board.
Green and red lights are on with different power source.
pins 0,1,2,3,6,7 .6mv
pins 4,9,10 .85v
Please advise
New 2220 Audio FX Sound Board Not Working
Re: New 2220 Audio FX Sound Board Not Working
- twier
Mike, here are the pictures.
- IMG_0311.jpg (147.81 KiB) Viewed 90 times
- IMG_0310.jpg (159.32 KiB) Viewed 90 times
Thank you.
The solder joint on trigger pin 11 looks like it hasn't made a good bond with the pad, but that wouldn't cause the low voltages you've measured on the other pins.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
