Hello!
This is a bit of an odd question, but I was wondering if it would be possible to use a Crickit and TFT Gizmo at the same time with one bluefruit?
I have a project for an interactive display where I need to use a solenoid, LED lighting, an LCD or other display, and a few sensors simultaneously, while doing some basic data logging regarding use.
Thank you for your time and assistance!
Using a Crickit and TFT Gizmo at the same time
- SleepyOrangutan
- dastels
Re: Using a Crickit and TFT Gizmo at the same time
The two conflict in the use of the A4/SCL and A5/SDA pads. The Cricket uses them for I2C and the Gizmo uses them for SCK & MOSI, respectively.
- SleepyOrangutan
Thank you for your help! That clears things up a bit. :-)
