mini pitft not working after upgrade
bill6460
Re: mini pitft not working after upgrade
Post by bill6460 »
pi@raspberrypi:~ $ ls /dev/i2c* /dev/spi*
ls: cannot access '/dev/spi*': No such file or directory
 /dev/i2c-1   /dev/i2c-2
pi@raspberrypi:~ $
adafruit_support_carter
SPI is not enabled.
I have tried turning SPI on and off from raspi-config with the same results.
This should work, if you reboot after.
However, the install script should have done that as well. This step of the guide:
https://learn.adafruit.com/adafruit-min ... up-3044241
takes you here:
https://learn.adafruit.com/circuitpytho ... rypi-linux
which then has you run a script:
https://learn.adafruit.com/circuitpytho ... spberry-pi
that would have done the same thing.
So not sure why enabling SPI on your Pi is not working. Try via raspi-config again. Enable SPI. Reboot. And then check again with:
bill6460
Post by bill6460 »
Thank you for your support. I did not expect this to take so long.
I did as the last post instructed and got the same result. I then created a folder /dev/spi and now I get this.
Last login: Thu Jan 12 18:52:30 2023 from 192.168.8.178
/dev/spi:
pi@raspberrypi:~ $
bill6460
Post by bill6460 »
When I run the blinkatest.py I get this.
Last login: Thu Jan 12 20:02:12 2023 from 192.168.8.178
pi@raspberrypi:~ $ python3 blinkatest.py
Hello blinka!
Digital IO ok!
I2C ok!
  File "/home/pi/blinkatest.py", line 16, in <module>
    spi = busio.SPI(board.SCLK, board.MOSI, board.MISO)
  File "/usr/local/lib/python3.9/dist-packages/busio.py", line 301, in __init__
    self._spi = _SPI(portId)
  File "/usr/local/lib/python3.9/dist-packages/adafruit_blinka/microcontroller/generic_linux/spi.py", line 25, in __init__
    self._spi = spi.SPI(device=(portid, 0))
  File "/usr/local/lib/python3.9/dist-packages/Adafruit_PureIO/spi.py", line 167, in __init__
    raise IOError("{} does not exist".format(device))
OSError: /dev/spidev0.0 does not exist
pi@raspberrypi:~ $
This will not work. The operating system needs to create the "folder", which it should if SPI is enabled via raspi-config and the system is rebooted. Please delete that folder.
It's a total mystery why raspi-config is not working.
Try running this command and post the output here:
cat /boot/config.txt | grep spi
bill6460
Post by bill6460 »
I removed the spi dir. There was nothing in it.
Last login: Thu Jan 12 21:27:40 2023 from 192.168.8.178
pi@raspberrypi:~ $ cat /boot/config.txt | grep spi
dtparam=spi=on
dtparam=spi=on
dtparam=spi=on
pi@raspberrypi:~ $
bill6460
Post by bill6460 »
And this has not changed
Last login: Thu Jan 12 21:29:43 2023 from 192.168.8.178
pi@raspberrypi:~ $
Did you try the suggestion to start over with a new OS image?
bill6460
Post by bill6460 »
Not yet. I made a traveling pi-hole using this https://learn.adafruit.com/pi-hole-ad-b ... -pi-zero-w and coupled it with a WIFI repeater / router that I use when I travel and I am leaving in a few days. That's what started all this. I did the update and upgrade as usual before a trip and the display stopped working. When I get time I will try to set it up on a new OS image. I am still unclear if Bullseye is supported at this time for the pi-hole project.
Thanks again for all the effort.
bill6460
Post by bill6460 »
I did a new install of ver raspberrypi-kernel 1:1.20220308~buster-1.
I did no updates or upgrades to this ver.
First I installed this project and the display worked fine.
https://learn.adafruit.com/adafruit-min ... spberry-pi
Then I followed the instructions for the pi-hole project and everything ran fine with no 404 errors.
https://learn.adafruit.com/pi-hole-ad-b ... mini-pitft
Pi Hole is running fine but the API to the Pi Hole is not working.
When I run stats.py I get this error.
pi@raspberrypi:~ $ sudo python3 stats.py
  File "stats.py", line 97, in <module>
    DNSQUERIES = data['dns_queries_today']
TypeError: list indices must be integers or slices, not str
So I tried this code
import json
import requests
api_url = 'http://localhost/admin/api.php'
r = requests.get(api_url)
data = json.loads(r.text)
print(data)
And I get this result.
pi@raspberrypi:~ $ sudo python3 test3.py
This is a new issue that has recently cropped up due to changes with Pi-Hole now requiring authentication to access the API data (which is used for the stats info). It took a while to figure this out and the stats.py code and guide will need to be updated (this is in works). If you're willing to make some minor changes to the stats.py code, there is a fix you can try here:
viewtopic.php?p=955696#p955696
bill6460
Post by bill6460 »
That fixed it. Thank you.
Cool, glad it worked. Thanks for letting us know.
Guide has now been updated. This affected both the OLED and TFT codes, both of which are now updated.
