I have had a project working for over a year on a PI Zero W and then I did the update to Bullseye and lost my display. I found this reference https://learn.adafruit.com/adafruit-min ... leshooting.
After following the posted instruction I got a 404 error for the GitHub link. I then searched GitHub and found the pin-kernal** file. It seemed to run ok but did not change the kernel version.
Any ideas? When will a new software update fix this problem?
mini pitft not working after upgrade
- adafruit_support_carter
Re: mini pitft not working after upgrade
Fixed the 404 error. The branch name had changed from master to main. Sorry about that.
Did you reboot after running the script?
- bill6460
The scrip install runs without errors however the instructions
cd ~
sudo pip3 install --upgrade adafruit-python-shell
wget https://raw.githubusercontent.com/adafr ... irmware.py
sudo python3 rpi-pin-kernel-firmware.py 1:1.20210527-1
does not work because the file that is created is "rpi_pin_kernel_firmware.py"
After I made the change and ran the script I still get a lot of errors on the script.
cd ~
Oops. Sorry. Yah, the name changes to, dashes turned into underscores. Updated that line as well in the guide.
What are the errors you are seeing running the script?
- bill6460
RASPBERRY_PI_ZERO_W detected.
PINNING --2023-01-05 17:24:39-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi0_1:1.20210527-1_armhf.deb
Resolving archive.raspberrypi.org (archive.raspberrypi.org)...
PINNING 176.126.240.86, 93.93.135.117, 46.235.231.151, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.86|:80...
PINNING connected.
HTTP request sent, awaiting response...
PINNING --2023-01-05 17:24:40-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-bin_1:1.20210527-1_armhf.deb
PINNING 93.93.130.212, 93.93.135.118, 93.93.135.141, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|93.93.130.212|:80...
PINNING connected.
PINNING 404 Not Found
2023-01-05 17:24:40 ERROR 404: Not Found.
PINNING --2023-01-05 17:24:40-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-dev_1:1.20210527-1_armhf.deb
PINNING 176.126.240.86, 93.93.130.212, 93.93.135.118, ...
PINNING connected.
PINNING --2023-01-05 17:24:41-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-doc_1:1.20210527-1_armhf.deb
PINNING 93.93.135.117, 176.126.240.86, 93.93.130.212, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|93.93.135.117|:80...
PINNING connected.
2023-01-05 17:24:41 ERROR 404: Not Found.
PINNING --2023-01-05 17:24:41-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-bootloader_1:1.20210527-1_armhf.deb
PINNING 46.235.231.151, 93.93.135.117, 176.126.240.86, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.151|:80...
PINNING connected.
PINNING --2023-01-05 17:24:42-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-kernel_1:1.20210527-1_armhf.deb
PINNING 46.235.231.111, 46.235.231.151, 93.93.135.117, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.231.111|:80...
PINNING connected.
2023-01-05 17:24:42 ERROR 404: Not Found.
PINNING --2023-01-05 17:24:42-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-kernel-headers_1:1.20210527-1_armhf.deb
PINNING 46.235.227.39, 46.235.231.111, 46.235.231.151, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.227.39|:80...
PINNING connected.
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in libraspberrypi0_1:1.20210527-1_armhf.deb
dpkg: error processing archive libraspberrypi0_1:1.20210527-1_armhf.deb (--install):
dpkg-deb --control subprocess returned error exit status 2
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in libraspberrypi-bin_1:1.20210527-1_armhf.deb
dpkg: error processing archive libraspberrypi-bin_1:1.20210527-1_armhf.deb (--install):
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in libraspberrypi-dev_1:1.20210527-1_armhf.deb
dpkg: error processing archive libraspberrypi-dev_1:1.20210527-1_armhf.deb (--install):
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in libraspberrypi-doc_1:1.20210527-1_armhf.deb
dpkg: error processing archive libraspberrypi-doc_1:1.20210527-1_armhf.deb (--install):
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in raspberrypi-bootloader_1:1.20210527-1_armhf.deb
dpkg: error processing archive raspberrypi-bootloader_1:1.20210527-1_armhf.deb (--install):
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in raspberrypi-kernel_1:1.20210527-1_armhf.deb
dpkg: error processing archive raspberrypi-kernel_1:1.20210527-1_armhf.deb (--install):
PINNING dpkg-deb: error: unexpected end of file in archive magic version number in raspberrypi-kernel-headers_1:1.20210527-1_armhf.deb
dpkg: error processing archive raspberrypi-kernel-headers_1:1.20210527-1_armhf.deb (--install):
REBOOT NOW? [Y/n]
- bill6460
I posted the entire stream when running the script but it still says not visible until approved by moderator. So here is the first of many 404 errors.
PINNING --2023-01-05 17:24:41-- http://archive.raspberrypi.org/debian/p ... _armhf.deb
PINNING connected.
PINNING connected.
- Franklin97355
You need to enclose this type of post in code tags or the bot thinks it might be malicious.
- bill6460
PINNING --2023-01-05 17:24:39-- http://archive.raspberrypi.org/debian/p ... _armhf.deb
PINNING connected.
PINNING --2023-01-05 17:24:40-- http://archive.raspberrypi.org/debian/p ... _armhf.deb
PINNING connected.
PINNING connected.
PINNING connected.
PINNING connected.
PINNING --2023-01-05 17:24:42-- http://archive.raspberrypi.org/debian/p ... _armhf.deb
PINNING connected.
PINNING connected.
REBOOT NOW? [Y/n]
- bill6460
oops Thanks.
Can you try starting over with a fresh image and see if the 404's repeat. Seems like there's either a distribution issue with the package repos or it may have something to do with the previous attempts that were based on the incorrect links in the guide (which hopefully are fixed now).
- bill6460
Thank you for the feedback. I ran the posted instructions again and did not get the 404 errors but as you can see there are still errors. Also I am running headless and my SSH connection has become unstable.
Is there another LCD for the Pi Zero that would be supported by Bullseye?
PINNING --2023-01-09 22:06:46-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi0_1:1.20210527-1_armhf.deb
PINNING Resolving archive.raspberrypi.org (archive.raspberrypi.org)...
PINNING 93.93.135.117, 46.235.230.122, 176.126.240.86, ...
PINNING connected.
PINNING --2023-01-09 22:06:51-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-bin_1:1.20210527-1_armhf.deb
PINNING 176.126.240.167, 93.93.135.141, 176.126.240.84, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|176.126.240.167|:80...
PINNING connected.
PINNING --2023-01-09 22:06:52-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-dev_1:1.20210527-1_armhf.deb
PINNING 93.93.135.117, 176.126.240.167, 93.93.135.141, ...
PINNING connected.
PINNING --2023-01-09 22:06:52-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/libraspberrypi-doc_1:1.20210527-1_armhf.deb
PINNING 46.235.230.122, 93.93.135.117, 176.126.240.167, ...
Connecting to archive.raspberrypi.org (archive.raspberrypi.org)|46.235.230.122|:80...
PINNING connected.
PINNING --2023-01-09 22:06:53-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-bootloader_1:1.20210527-1_armhf.deb
PINNING 46.235.231.111, 46.235.231.145, 176.126.240.86, ...
PINNING connected.
2023-01-09 22:07:03 ERROR 404: Not Found.
PINNING --2023-01-09 22:07:03-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-kernel_1:1.20210527-1_armhf.deb
PINNING 46.235.227.39, 46.235.231.111, 46.235.231.145, ...
PINNING connected.
PINNING --2023-01-09 22:07:04-- http://archive.raspberrypi.org/debian/pool/main/r/raspberrypi-firmware/raspberrypi-kernel-headers_1:1.20210527-1_armhf.deb
Resolving archive.raspberrypi.org (archive.raspberrypi.org)... 93.93.130.212, 46.235.227.39, 46.235.231.111, ...
PINNING connected.
2023-01-09 22:07:04 ERROR 404: Not Found.
PINNING Errors were encountered while processing:
REBOOT NOW? [Y/n]
Do you have more info on what is happening here?Also I am running headless and my SSH connection has become unstable.
You are still getting 404's, just not the same. Some of the package pulls look like they worked. If you are having SSH troubles with the same Pi, it could be network connection related.
- bill6460
I have been trying to sort out the root cause.
I have used this page https://learn.adafruit.com/adafruit-min ... thon-setup
When I run the test I get these errors. I have tried turning SPI on and off from raspi-config with the same results.
Last login: Wed Jan 11 15:36:03 2023 from 192.168.8.179
pi@raspberrypi:~ $ python3 rgb_display_minipitfttest.py
File "/home/pi/rgb_display_minipitfttest.py", line 17, in <module>
board.SPI(),
File "/usr/local/lib/python3.9/dist-packages/board.py", line 344, in SPI
return busio.SPI(SCLK, MOSI, MISO)
File "/usr/local/lib/python3.9/dist-packages/busio.py", line 301, in __init__
self._spi = _SPI(portId)
File "/usr/local/lib/python3.9/dist-packages/adafruit_blinka/microcontroller/generic_linux/spi.py", line 25, in __init__
self._spi = spi.SPI(device=(portid, 0))
File "/usr/local/lib/python3.9/dist-packages/Adafruit_PureIO/spi.py", line 167, in __init__
raise IOError("{} does not exist".format(device))
OSError: /dev/spidev0.0 does not exist
pi@raspberrypi:~ $
- bill6460
currently my display looks like this.
- mini display.jpg (449.38 KiB) Viewed 77 times
What shows up if you run?
https://learn.adafruit.com/circuitpytho ... pi-2993390
ls /dev/i2c* /dev/spi*
