Adafruit_DPS310 Library Usage
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
packetkiller
Post by packetkiller »
I am an educator teaching hardware and software integration. We are attempting to use an Adafruit DPS310 Module over SPI to get each of the hardware registers values for use in high precision and rapid measurements that are to be used to calculate high precision byproducts like altitude.
We have reviewed the library and examples but are not sure how one would use the library to pull certain registers like:
COEF (0x10 to 0x21)
Would like to get to the point where accurate altitude can be calculated (much more precise than the existing altitude calculation that seems to be just a rough estimate and not sure it is accounting for temp or being filtered.
We have created a few examples just to prove out how to accomplish micro tasks (like pulling a register value), but eventually wish to read all register values so can perform high precision measurements as fast as possible and also apply the coefficients per the datasheet.
Please keep in mind we are integrator class and not programming class :(
Our code looks like this for pulling temp directly from register using wire library...would be good if could just use Adafruit_DPS310 library directly, but we do not know how or if it is possible:
#include <Adafruit_DPS310.h>
#define dps_cont_prestemp_mode DPS310_CONT_PRESTEMP
int32_t tmp_reading = 0;
int32_t kT = 1040384;
int32_t tmp_raw_sc = 0;
Adafruit_DPS310 dps;
  Serial.begin(115200);
  while (!Serial);
  delay(10);
  Serial.println(F("DPS310 Startup (initialize I2C interface)"));
  Serial.println(F("DPS310 I2C Address set to: "));
  Serial.print(F(" decimal: "));
  Serial.println(DPS310_I2CADDR_DEFAULT);
  Serial.print(F("     hex: 0x"));
  Serial.println(DPS310_I2CADDR_DEFAULT, HEX);
  if (! dps.begin_I2C(DPS310_I2CADDR_DEFAULT)) {         // Can pass in I2C address here
    Serial.println(F("Failed to find DPS"));
    while (1) yield();
  Serial.println(F("DPS OK!"));
  Serial.println();
  Serial.println(F("Setting the DPS310 to DPS310_64HZ measuring rate and DPS310_64SAMPLES oversampling rate."));
  dps.configurePressure(DPS310_64HZ, DPS310_64SAMPLES);
  dps.configureTemperature(DPS310_64HZ, DPS310_64SAMPLES);
  Serial.println(F("DPS310 set to DPS310_64HZ measuring rate and DPS310_64SAMPLES oversampling rate."));
  Serial.println();
  Serial.println(F("Setting the DPS310 to DPS310_CONT_PRESTEMP mode."));
  dps.setMode(dps_cont_prestemp_mode);
  Serial.println(F("DPS310 set to mode DPS310_CONT_PRESTEMP."));
  Serial.println();
  Serial.println(F("Reading the TMPB2 to TMPB0 registers."));
  Wire.beginTransmission(DPS310_I2CADDR_DEFAULT); //transmit to sensor (using default address)
  Wire.write(byte(DPS310_TMPB2));      // sets register pointer to TMP_B2 register (0x03)
  Wire.endTransmission();      // stop transmitting
  Wire.requestFrom(DPS310_I2CADDR_DEFAULT, 3);    // request 3 bytes from slave device 0x77
  if (3 <= Wire.available()) { // if three bytes were received
    tmp_reading = Wire.read();  // receive high byte (TMP_B2)
    tmp_reading = tmp_reading << 8;    // shift byte by 8 bits
    tmp_reading |= Wire.read(); // receive middle byte (TMP_B1)
    tmp_reading |= Wire.read();  // receive low byte (TMP_B0)
    Serial.println(F("TMP_Bn (2's Complement)(hex): "));
    Serial.println(tmp_reading, HEX);   // print the 'reading' in hexadecimal
    Serial.println();
    Serial.println(F("TMP_Bn (raw): "));
    Serial.println(tmp_reading);   // print the 'reading' in decimal
    Serial.println();
    Serial.println(tmp_reading, BIN);   // print the 'reading' in binary
    Serial.println();
    tmp_raw_sc = ( tmp_reading / kT );
    Serial.println(F("TMP (raw_sc): "));
    Serial.println(tmp_raw_sc);   // print the 'reading' in decimal
    Serial.println(tmp_raw_sc, BIN);   // print the 'reading' in binary
    Serial.println();
    Serial.println(F("TMPB2 to TMPB0 registers read."));
    Serial.println();
  //Serial.println(F("Do nothing forever..."));
How can we use the library, or is it possible to get from the library the COEF (0x10 to 0x21) registers?
adafruit_support_mike
Re: Adafruit_DPS310 Library Usage
packetkiller wrote: Mon Jan 02, 2023 1:52 am Please keep in mind we are integrator class and not programming class :(
With microcontrollers, there's very little difference. You don't have to teach algorithmic analysis, but 'not wanting to program' is as much of a hindrance as 'not wanting to use wire'.
packetkiller wrote: Mon Jan 02, 2023 1:52 am We have reviewed the library and examples but are not sure how one would use the library to pull certain registers like:
COEF (0x10 to 0x21)
Look at the library code itself:
https://github.com/adafruit/Adafruit_DPS310
The header file contains symbolic definitions for the registers and settings listed in the datasheet:
https://github.com/adafruit/Adafruit_DP ... .h#L29-L37
and the source file shows how to use them:
https://github.com/adafruit/Adafruit_DP ... #L242-L254
The DPS310 library uses a couple of support libraries that gives all sensors a common interface:
https://github.com/adafruit/Adafruit_Sensor
and provide a common interface for protocols like SPI and I2C:
https://github.com/adafruit/Adafruit_BusIO
If you're reading and writing registers directly, you can ignore the Adafruit_Sensor library without much effort, but extracting the SPI code from the Adafruit_BusIO library will take a bit of digging and reverse engineering.
packetkiller
Your reply was very helpful. Thank you. We are programming but not that great at it...thus why we a school :) But we are learning fast!
The Adafruit_DPS310.cpp told us what we were looking for. Specifically that the library (very nice) uses the coefficients as we wanted, so we do not need to do that work. We did find the altitude calc too...and are using it now. We have the device connected and working but with one unexpected result...the altitude drifts greatly when just sitting on the desk and in constant temperature. We suspect some outside weather to have some affect but the drift is beyond what can be accounted for. Do you know of a way to address the drift? We are close to sealevel and even with calibration, we see the same result...altitude climes or drops (even when covered) in the range of +-1000 cm in less than an hour.
While not too bad, it enough to cause issues with our experiments. Is there some fancy programming math that might slow the drift? Maybe by using a bunch of samples over time?
packetkiller wrote: Wed Jan 04, 2023 10:58 pm We are close to sealevel and even with calibration, we see the same result...altitude climes or drops (even when covered) in the range of +-1000 cm in less than an hour.
For that amount of change and that period of time, I'd guess that's evidence of the local barometric pressure changing over time.
packetkiller wrote: Wed Jan 04, 2023 10:58 pm Is there some fancy programming math that might slow the drift? Maybe by using a bunch of samples over time?
The fancy tricks usually turn around and bite you later..
From a standpoint of metrology, you're dealing with a basic form of uncertainty: your altitude readings contain a mix of:
1 - air pressure change from change in distance to the ground, plus
2 - air pressure change from the weather
And the single number you get as a result doesn't give you enough information to know the ratio between those terms.
What you need is a second reference value: add another DPS310 that you know is stationary, and use it to track changes in the local air pressure over time. That will give you a reliable estimate for term 2, which you can subtract from your main DPS310's readings to get a better estimate of the altitude.
packetkiller
That makes a lot of sense. A second reference point would definitely help. Since our project moves through the atmosphere and we do have a way to send the stationary data to the device in motion, we will work on adding that feature. In addition, another teacher has provided some methods of mediating values locally to slow the rate of change. Still just averaging but at least not as fast as the barometer jumps around...see below and we look forward to your feedback on other code improvements we could make:
#include <SPI.h>
#include <Wire.h>
#include <nRF24L01.h>
#include <RF24.h>
#include "Adafruit_DPS310b.h" //Adafruit_DPS310.cpp mods
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#define LED_PIN 2
boolean ledOn = false;
int ledCounter = 0;
#define CE_PIN   9
#define CSN_PIN 10
const uint64_t pipeOut =  0xE8E8F0F0E1LL; // address through which two modules communicate
RF24 radio(CE_PIN, CSN_PIN); // Create an RF24 object using CE, CSN pins
int packetCounts[10];
int packetCountIndex = 0;
int packetCountTotal = 0;
char ppsBuf[16];
char dropsBuf[16];
char pressBuf[16];
char tempBuf[16];
char altBuf[16];
char lonBuf[16];
char latBuf[16];
unsigned long packetsSent = 0;
unsigned long lastSendTime = 0;
unsigned long drops = 0;
struct PacketData {
  long lon;
  long lat;
  int32_t pktpressure;
  int32_t pkttemperature;
  int32_t pktaltitude;
  long velN;
  long velE;
PacketData data;
void resetData() {
  data.lon = 0;
  data.lat = 0;
  data.pktpressure = 0;
  data.pkttemperature = 0;
  data.pktaltitude = 0;
#define GPSSERIAL Serial
const unsigned char UBLOX_INIT[] PROGMEM = {
  0xB5,0x62,0x06,0x16,0x08,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x25,0x90, // Disable SBAS
   0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x24, // GxGGA off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x2B, // GxGLL off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x02,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x32, // GxGSA off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x39, // GxGSV off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x04,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x40, // GxRMC off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x05,0x00,0x00,0x00,0x00,0x00,0x01,0x05,0x47, // GxVTG off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0xDC, //NAV-PVT off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x12,0xB9, //NAV-POSLLH off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xC0, //NAV-STATUS off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x22,0x29, //NAV-VELNED off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x02,0x00,0x01,0x00,0x00,0x00,0x00,0x13,0xBE, //NAV-POSLLH on
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x12,0x00,0x01,0x00,0x00,0x00,0x00,0x23,0x2E, //NAV-VELNED on
  0xB5,0x62,0x06,0x08,0x06,0x00,0x64,0x00,0x01,0x00,0x01,0x00,0x7A,0x12, //(10Hz)
const unsigned char UBX_HEADER[]        = { 0xB5, 0x62 };
const unsigned char NAV_POSLLH_HEADER[] = { 0x01, 0x02 };
const unsigned char NAV_VELNED_HEADER[] = { 0x01, 0x12 };
enum _ubxMsgType {
  MT_NONE,
  MT_NAV_POSLLH,
  MT_NAV_VELNED
struct NAV_POSLLH {
  unsigned char cls;      // 0x01
  unsigned char id;       // 0x02
  unsigned short len;     // 28
  unsigned long iTOW;     // millisecond time of week
  long lon;               // longitude
  long lat;               // latitude
  long height;            // height above ellipsoid
  long hMSL;              // height above mean sea level
  unsigned long hAcc;     // horizontal accuracy
  unsigned long vAcc;     // vertical accuracy
struct NAV_VELNED {
  unsigned char id;       // 0x12
  unsigned short len;     // 36
  long velN;              // north velocity (cm/s)
  long velE;              // east velocity (cm/s)
  long velD;              // down velocity (cm/s)
  unsigned long speed;    // 3d (cm/s)
  unsigned long gSpeed;   // ground speed (2d)
  long heading;           // heading of motion (2d)
  unsigned long sAcc;     // speed accuracy
  unsigned long cAcc;     // course/heading accuracy
union UBXMessage {
  NAV_POSLLH navPosllh;
  NAV_VELNED navVelned;
UBXMessage ubxMessage;
void calcChecksum(unsigned char* CK, int msgSize) {
  memset(CK, 0, 2);
  for (int i = 0; i < msgSize; i++) {
    CK[0] += ((unsigned char*)(&ubxMessage))[i];
    CK[1] += CK[0];
boolean compareMsgHeader(const unsigned char* msgHeader) {
  unsigned char* ptr = (unsigned char*)(&ubxMessage);
  return ptr[0] == msgHeader[0] && ptr[1] == msgHeader[1];
int processGPS() {
  static int fpos = 0;
  static unsigned char checksum[2];
  static byte currentMsgType = MT_NONE;
  static int payloadSize = sizeof(UBXMessage);
  while ( GPSSERIAL.available() ) {
    byte c = GPSSERIAL.read();
    if ( fpos < 2 ) {
      if ( c == UBX_HEADER[fpos] )
        fpos++;
      else
        fpos = 0; // Reset to beginning state.
    else {
      if ( (fpos-2) < payloadSize )
        ((unsigned char*)(&ubxMessage))[fpos-2] = c;
      fpos++;
      if ( fpos == 4 ) {
        if ( compareMsgHeader(NAV_POSLLH_HEADER) ) {
          currentMsgType = MT_NAV_POSLLH;
          payloadSize = sizeof(NAV_POSLLH);
        else if ( compareMsgHeader(NAV_VELNED_HEADER) ) {
          currentMsgType = MT_NAV_VELNED;
          payloadSize = sizeof(NAV_VELNED);
        else {
          // unknown message type, bail
          fpos = 0;
          continue;
      if ( fpos == (payloadSize+2) ) {
        calcChecksum(checksum, payloadSize);
      else if ( fpos == (payloadSize+3) ) {
        if ( c != checksum[0] ) {
          fpos = 0;
      else if ( fpos == (payloadSize+4) ) {
        fpos = 0; // We will reset the state regardless of whether the checksum matches.
        if ( c == checksum[1] ) {
          return currentMsgType;
      else if ( fpos > (payloadSize+4) ) {
        fpos = 0;
  return MT_NONE;
/*Baro Variables Begin*/
#define SENSOR_NEEDS_SAMPLES      0
#define SENSOR_NEEDS_CALCULATION  1
#define SENSOR_NEEDS_PROCESSING   2
#define SAMPLE_COUNT_MAX   48
#define SENSOR_SAMPLE_COUNT 21
#define SAMPLE_COUNT 20
#define SAMPLES_MEDIAN 3
int32_t baroPressure = 0;
int32_t baroTemperature = 0;
int32_t baroAlt = 0;
static uint32_t baroGroundAltitude = 0;
static uint32_t baroGroundPressure = 0;
// static uint32_t baroGroundPressure = 1011.50; // hPa, get from local air port readings
int32_t readingSum = 0;
int32_t alt_start_reading = 0; // altitude at barometer startup (in cm)
int32_t alt_delta_reading = 0; // alt_delta_reading = alt_reading - alt_start_reading (in cm)
int32_t alt_reading = 0;       // current barameter alt reading (in cm)
int32_t pktpressure = 0;       // value passed from tag to controller
int32_t pkttemperature = 0;    // value passed from tag to controller
int32_t pktaltitude = 0;       // value passed from tag to controller
int count = 0;
boolean doneCalibration = false;
Adafruit_Sensor *dps_temp = dps.getTemperatureSensor();  // create dps temperature object
Adafruit_Sensor *dps_pressure = dps.getPressureSensor(); // create dps pressure object
#define QMF_SORT(a,b) { if ((a)>(b)) QMF_SWAP((a),(b)); }
#define QMF_SWAP(a,b) { int32_t temp=(a);(a)=(b);(b)=temp; }
#define QMP_COPY(p,v,n) { int32_t i; for (i=0; i<n; i++) p[i]=v[i]; }
int32_t quickMedianFilter3(int32_t * v) {
    int32_t p[3];
    QMP_COPY(p, v, 3);
    QMF_SORT(p[0], p[1]); QMF_SORT(p[1], p[2]); QMF_SORT(p[0], p[1]) ;
    return p[1];
static int32_t applyMedianFilter(int32_t newReading) {
    static int32_t FilterSamples[SAMPLES_MEDIAN];
    static int currentFilterSampleIndex = 0;
    static bool medianFilterReady = false;
    int nextSampleIndex;
    nextSampleIndex = (currentFilterSampleIndex + 1);
    if (nextSampleIndex == SAMPLES_MEDIAN) {
        nextSampleIndex = 0;
        medianFilterReady = true;
    FilterSamples[currentFilterSampleIndex] = newReading;
    currentFilterSampleIndex = nextSampleIndex;
    if (medianFilterReady)
        return quickMedianFilter3(FilterSamples);
    else
        return newReading;
static uint32_t recalculateTotal(uint8_t SampleCount, uint32_t readingTotal, int32_t newReading) {
  static int32_t readingSamples[SAMPLE_COUNT_MAX];
  static int currentSampleIndex = 0;
  nextSampleIndex = (currentSampleIndex + 1);
  if (nextSampleIndex == SampleCount) {
  readingSamples[currentSampleIndex] = applyMedianFilter(newReading);
  readingTotal += readingSamples[currentSampleIndex];
  readingTotal -= readingSamples[nextSampleIndex];
  currentSampleIndex = nextSampleIndex;
  return readingTotal;
void baroUpdate(uint32_t currentTime) {
  static uint32_t baroDeadline = 0;
  static int state = SENSOR_NEEDS_SAMPLES;
  if ((int32_t)(currentTime - baroDeadline) < 0)
    return;
  baroDeadline = 0;
  switch (state) {
  case SENSOR_NEEDS_SAMPLES:
    sensors_event_t temp_event, pressure_event;
    while (!dps.temperatureAvailable() || !dps.pressureAvailable()) {
      return; // wait until there's something to read
    dps.getEvents(&temp_event, &pressure_event);
    baroTemperature = temp_event.temperature;
    baroPressure = pressure_event.pressure;
    alt_reading = (dps.readAltitude() * 100 );           // in cm
    alt_delta_reading = alt_reading - alt_start_reading; // in cm
    state = SENSOR_NEEDS_CALCULATION;
    baroDeadline += 10000;
    break;
  case SENSOR_NEEDS_CALCULATION:
    state = SENSOR_NEEDS_PROCESSING;
    break;
  case SENSOR_NEEDS_PROCESSING:
    readingSum = recalculateTotal(SENSOR_SAMPLE_COUNT, readingSum, alt_reading);
    break;
  baroDeadline += micros();        // make sure deadline is set after calling baro callbacks
  pinMode(LED_PIN, OUTPUT);
  pinMode(CSN_PIN, OUTPUT); // Arduino Uno R3 (Atmega 328 datasheet) pin 10 must set as OUTPUT to make the chip work as an SPI master
  GPSSERIAL.begin(9600);
  for(int i = 0; i < (int)sizeof(UBLOX_INIT); i++) {
    GPSSERIAL.write( pgm_read_byte(UBLOX_INIT+i) );
    delay(5); // simulating a 38400baud pace (or less), otherwise commands are not accepted by the device.
  resetData();
    while (1) yield();
  dps.setMode(DPS310_CONT_PRESTEMP);
  alt_start_reading = ( dps.readAltitude() * 100 );  // in cm
  alt_reading = alt_start_reading;
  radio.begin();
  radio.setDataRate(RF24_250KBPS);
  radio.setAutoAck(false);
  radio.openWritingPipe(pipeOut);
  radio.stopListening(); // set module as transmitter
  delay(5000); // wait a few seconds to close the device
void toggleLed() {
  ledOn = ! ledOn;
  digitalWrite(LED_PIN, ledOn);
void sendData() {
    radio.write(&data, sizeof(PacketData));
    packetsSent++;
    if ( ledCounter++ > 5 ) {
      toggleLed();
      ledCounter = 0;
    lastSendTime = millis();
  unsigned long now = millis();
  if ( now - lastSendTime > 1000 )
    drops = 1;
  else
    drops = 0;
  unsigned long now = micros();
  baroUpdate(now);
  if ( !doneCalibration ) {
    if ( count++ > 200 ) {
      for (int i = 0; i < 200; i++) {
        //performBaroCalibrationCycle();
        //delay(10);
      doneCalibration = true;
  else {
    // Get altitude
    data.pktpressure = baroPressure;              // this value gets sent over the radio (hPa)
    data.pkttemperature = baroTemperature;        // this value gets sent over the radio (*C)
    data.pktaltitude = alt_delta_reading;         // this value gets sent over the radio (cm)
  sendData();
  int msgType = processGPS();
  if ( msgType == MT_NAV_POSLLH ) {
Serial.print(posllh.lon/10000000.0f);
    data.lon = ubxMessage.navPosllh.lon;
    data.lat = ubxMessage.navPosllh.lat;
  else if ( msgType == MT_NAV_VELNED ) {
    data.velN = ubxMessage.navVelned.velN;
    data.velE = ubxMessage.navVelned.velE;
  delay(20);
  // Start sensor time = 10:00 PM CST
  // PPS = 67
  // PRS = 1026
  // TMP = 29
  // Alt = between -1 and 5 (try to beat -5000) in cm
  // new code Alt = between 15 and -150 (much better) in cm and matches manual calculations
It will be a good idea to test any averaging system you use on some test data. A dozen pulses of a square wave is good.
Do one series, double the time between the rising and falling edges (halve the frequency) and do another series, double the time again, etc. Then run another series of tests where you double the amplitude of the pulses.
Filters have the same uncertainty problem you've already seen: they don't know how much of the input is real change and how much is unwanted noise. There's always an assumption that the filter will block more of the stuff you don't want than stuff you do want. It's hard to tell if those assumptions are valid unless you know what effect the filter has in general.
The math related to filtering shows that you can learn everything you need to know about a filter's response from an 'impulse': an infinitely narrow pulse that carries a defined amount of energy. In general, filters redistribute that energy over time. It's hard to generate a good approximation of an impulse, but the rising and falling edges of a square wave are A) mathematically related to impulses, and B) much easier to generate.
Watching the way a filter responds to square waves will give you a good idea of how the filter responds to input, and will help you understand the effect the filter can have on your real data.
Return to “For Educators”
