The pico board type is not defined in the OneWire.h header file (see below). Each section contains a few lines of gpio (board specific) defines -> mojo for the lower level DallasTemp code (I think).
The Arduino IDE is elegant for it's simplicity & I'm hoping I can stick with it for an educational environment. Any suggestions and/or condolences are appreciated.
Installed
Arduino IDE w/ board Raspberry Pi Pico W (rp2040)
Version: 2.0.3
Date: 2022-12-05T09:27:52.215Z
CLI Version: 0.29.0 [76251df9]
Copyright © 2023 Arduino SA
Installed the following via LIBRARY MANAGER
MAX31850 DallasTemp by Adafruit Version 1.14
MAX31850 OneWire by Adafruit Version 1.1.1
/home/x/Arduino/libraries/MAX31850_OneWire/OneWire.h:167:2: error: #error "Please define I/O register types here"
167 | #error "Please define I/O register types here"
OneWire pico w using Arduino IDE
- adafruit_support_carter
Re: OneWire pico w using Arduino IDE
Opened a new issue for this here:
https://github.com/adafruit/MAX31850_OneWire/issues/7
- robert070
Update & Observations
I modified OneWire.h to include the following defines for the pico chip:
[*]#define IO_REG_TYPE uint8_t
#define PIN_TO_BASEREG(pin) ( (volatile IO_REG_TYPE *) NULL )
#define PIN_TO_BITMASK(pin) ( (IO_REG_TYPE) pin )
#define IO_REG_ASM
#define DIRECT_READ(base, pin) digitalRead(pin)
#define DIRECT_WRITE_LOW(base, pin) digitalWrite(pin,0)
#define DIRECT_WRITE_HIGH(base, pin) digitalWrite(pin,1)
#define DIRECT_MODE_INPUT(base, pin) pinMode(pin,INPUT)
#define DIRECT_MODE_OUTPUT(base, pin) pinMode(pin,OUTPUT)
**** Note -This looks like Arduino code as this is targeted to the pico using the Arduino IDE ****
These 'defines' were verified using a simple gpio. Once applied to OneWire.cpp, a call to OneWire.cpp:search() executes the search() -> reset() path. The sad news is that the chip appears to hang near the bottom of reset() somewhere in the block around line 159
noInterrupts();
DIRECT_MODE_INPUT(reg, mask); // allow it to float
delayMicroseconds(70);
r = !DIRECT_READ(reg, mask); // reads a high
interrupts();
Suggestions & Condolences are a appreciated.
#define IO_REG_ASM
noInterrupts();
interrupts();
- robert070
The suggested defines posted Jan 6 work. However, there's a larger issue: the pico does not like the disabling / enabling of interrupts to assist with the strict timing of the screwy onewire interface. The system will hang.
A workaround was to comment out all interrupt enable/disables and to run the code on the idle second core.
