I accidentally pulled my STEMMA QT connector off a Feather V2 board. It was entirely my fault, I had it stuck into the socket tightly and I had the wire pulling on it.
I am thinking about trying to reconnect it because I liked its ease of use. I have been able to line up the 4 pins to what looks like 4 slots where they go on the board. On the other side of the connector, it looks like there are two metallic looking blocks.
I was thinking I would use my soldering iron and just try to heat up the pin area to see if the pins drop back in. I was wondering about those two blocks on the other end of the connector. Do you know if they originally held-in the connector in any way, or are they just there as stoppers? Trying to decide if I should heat those a bit as well.
Reconnect Stemma QT
- dastels
Re: Reconnect Stemma QT
The two on the open side of the connector are generally just to secure it to the board, as the 4 connections are on the other side. Have a close look at the board to confirm that the pads/traces are still intact. Feel free to post a clear closeup there for more eyes on it.
- forum_questions_1
Ok, thanks very much Dave.
I'll take a picture tonight and post it to show you.
- forum_questions_1
Pictures attached. First one is not great quality, it is where I saw those raised metallic "posts". Second one shows the pins, which I can't believe I was able to line back up!
- v2 connector back.jpeg (172.06 KiB) Viewed 2047 times
- V2 Connector.jpeg (303.5 KiB) Viewed 2047 times
- dastels
Ah. A vertical one. Same thing. 4 contacts for (V+, gnd, SDA, SCL) and two mounting tabs on the other side.
- forum_questions_1
Cool, thanks. What do you think of the solder pads? It looks to me like there is still some material there near the pins. It'll be a tight space but maybe they'll take with a little ironing?
- dastels
Looks like it might be ok. It could just have been some weak solder. Worth a try!
- forum_questions_1
Ok, thanks Dave. Yes, I think I'll give it a go. Thanks for your insight on the board component and what it is connected to.
